FreeBSD install fails with Error code 1
jbruyet
Post by jbruyet »
Hey all, I'm trying to install Nagios from port on a 9.1 server and it's not working. Here's what I'm seeing (notice the Error code 1 errors at the end of the failed install):
root@FreeNag:/usr/ports/net-mgmt/nagios # make install clean
===>   nagios-3.5.1 depends on file: /usr/local/bin/autoconf-2.69 - not found
===>    Verifying install for /usr/local/bin/autoconf-2.69 in /usr/ports/devel/autoconf
===>  Installing for autoconf-2.69
===>   autoconf-2.69 depends on executable: gm4 - found
===>   autoconf-2.69 depends on executable: autoconf-wrapper - found
===>   autoconf-2.69 depends on file: /usr/local/bin/perl5.12.4 - found
===>  Checking if devel/autoconf already installed
pkg_add: package 'autoconf-2.69' or its older version already installed
*** [install-package] Error code 1
Stop in /usr/ports/devel/autoconf.
*** [build-depends] Error code 1
Stop in /usr/ports/net-mgmt/nagios.
*** [install] Error code 1
I thought maybe the install was just saying the last three packages were already installed but when I tried to navigate to the Nagios folder it wasn't there. Googling this error doesn't give me anything useful.
Joe B
Re: FreeBSD install fails with Error code 1
Post by slansing »
What version of nagios are you trying to install and what documentation are you following?
jbruyet
Post by jbruyet »
I'm trying to install Nagios 3.5.1 (that's not from the port but from the install screen) and the documentation is here:
http://www.unixmen.com/how-to-install-a ... n-freebsd/
Joe B
abrist
Red Shirt
Post by abrist »
Lets check for the autoconf bin and check its version:
$(which autoconf) -V
jbruyet
Post by jbruyet »
Ok, now I know where autoconf is located but I wasn't able to find its version this way:
$ (which autoconf) -v
Syntax error: word unexpected
$ (which autoconf) -V
$ which autoconf -v
$ which autoconf -V
Then I decided to try it this way:
$ autoconf -v
autoconf-2.68: error: no input file
I've seen a couple of sites that say v2.68 is broken. Should I head into ports and do a make install clean? I did a portsnap about four days ago.
Joe B
abrist
Red Shirt
Post by abrist »
jbruyet wrote: I've seen a couple of sites that say v2.68 is broken. Should I head into ports and do a make install clean? I did a portsnap about four days ago.
I noticed the bug reports for the version as well. Please ./configure and make clean.
jbruyet wrote:Ok, now I know where autoconf is located but I wasn't able to find its version this way:
[snip]
The whole line was meant to be entered:
Or another method with the backticks:
`which autoconf` -V
jbruyet
Post by jbruyet »
I'm in the autoconf folder in ports but the ./configure didn't work:
root@FreeNag:/usr/ports/devel/autoconf # ./configure
./configure: Command not found.
Any other ideas?
Joe B
I wonder if you have bash installed. If you don't - try installing it.
http://www.cyberciti.biz/faq/freebsd-bash-installation/
Hope this helps.
jbruyet
Post by jbruyet »
I went ahead and did the install for bash but no joy. I still get the "Command not found" error when I try to run ./configure. Anyone have any other ideas?
Joe B
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Are you doing ./configure from the nagios source directory or are you attempting to reinstall autoconf? ./configure is usually just located in the root directory of the application you are trying to build and install.
