nagiosxi stuck at applying configuration
Re: nagiosxi stuck at applying configuration
abrist,
Thank you.
1) We have less than 10 hosts and services each since it's only in testing phase.
2) please see attached.
3) I have made the changes.
The problem is still there after a restart after step 3 above. Also I cannot restart nagios service with the following error message:
[root@sm5nag01 ~]# service nagios restart
Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
Thank you.
Just as I thought. xi_timeperiod_24x7 exists in both the xiobjects.cfg and timeperiods.cfg file. Our update script should have fixed this conflict on update - but it obviously did not. Comment out the following lines (by adding a '#' to the beginning of each line) in the /usr/local/nagios/etc/static/xiobjects.cfg file so that it resembles:
And then verify your config:
If it checks out ok, restart nagios. If it does not check out ok, post the errors here.
#define timeperiod{
# timeperiod_name xi_timeperiod_24x7
# alias 24x7
# sunday 00:00-24:00
# monday 00:00-24:00
# tuesday 00:00-24:00
# wednesday 00:00-24:00
# thursday 00:00-24:00
# friday 00:00-24:00
# saturday 00:00-24:00
# }Code: Select all
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgFormer Nagios employee
It failed, here's the error message:
root@sm5nag01:~[root@sm5nag01 ~]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.
cfg
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/www.google.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/AL5BITEC01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/SM5UNITFS01.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Exchange03-MEVS1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Ironmail-CT1.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/www.google.com.cfg'...
Processing object config file '/usr/local/nagios/etc/services/AL5BITEC01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/SM5UNITFS01.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Exchange03-MEVS1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/CT1.cfg'...
Checking services...
Error: Contact 'tobiasa' specified in service 'CPU Usage' for host 'AL5BITEC01' is not defined anywhere!
Error: Contact 'tobiasa' specified in service 'Drive C: Disk Usage' for host 'AL5BITEC01' is not defined anywhere!
Error: Contact 'tobiasa' specified in service 'Memory Usage' for host 'AL5BITEC01' is not defined anywhere!
Error: Contact 'tobiasa' specified in service 'Ping' for host 'AL5BITEC01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Symantec Endpoint Protection' for host 'AL5BITEC01' is not defined anywhere!
Error: Contact 'tobiasa' specified in service 'Uptime' for host 'AL5BITEC01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'OWA HTTP' for host 'Exchange03-MEVS1' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Ping' for host 'Exchange03-MEVS1' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'SMTP' for host 'Exchange03-MEVS1' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Ping' for host 'Ironmail-CT1' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Application EventLog' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'CPU Usage' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Drive C: Disk Usage' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Drive D: Disk Usage' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'EventLog Agent' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Logon Errors' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Memory Usage' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Page File Usage' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Ping' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Security EventLog' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Server Work Queues' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Symantec Endpoint Protection' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'System EventLog' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Uptime' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Windows Time' for host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'ActiveHostChecks 5mn' for host 'localhost' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'ActiveServiceChecks 5mn' for host 'localhost' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'PassiveHostChecks 5mn' for host 'localhost' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'PassiveServiceChecks 5mn' for host 'localhost' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'DNS IP Match' for host 'www.google.com' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'DNS Resolution' for host 'www.google.com' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'HTTP' for host 'www.google.com' is not defined anywhere!
Error: Contact 'zhangn' specified in service 'Ping' for host 'www.google.com' is not defined anywhere!
Checked 41 services.
Checking hosts...
Warning: Host 'AL5BITEC01' has no default contacts or contactgroups defined!
Error: Contact 'zhangn' specified in host 'Exchange03-MEVS1' is not defined anywhere!
Error: Contact 'zhangn' specified in host 'Ironmail-CT1' is not defined anywhere!
Error: Contact 'zhangn' specified in host 'SM5UNITFS01' is not defined anywhere!
Error: Contact 'zhangn' specified in host 'www.google.com' is not defined anywhere!
Checked 6 hosts.
Checking host groups...
Checked 8 host groups.
Checking service groups...
Checked 3 service groups.
Checking contacts...
Checked 3 contacts.
Checking contact groups...
Checked 2 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Error: Contact 'zhangn' specified in host escalation for host 'Exchange03-MEVS1' is not defined anywhere!
Error: Contact 'zhangn' specified in host escalation for host 'SM5UNITFS01' is not defined anywhere!
Checked 4 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 109 commands.
Checking time periods...
Checked 12 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 1
Total Errors: 41
***> One or more problems was encountered while running the pre-flight check...
cfg
Nagios Core 3.5.0
License: GPL
Checking hosts...
Checked 6 hosts.
Checked 3 contacts.
Total Warnings: 1
Total Errors: 41
You need to either create the following contacts, or remove them from any objects:
tobiasa
zhangnFormer Nagios employee
I tried to remove these 2 contacts directly, but it showed they are linked to services and hosts, so I removed all services and hosts from Nagios, then deleted both contact accounts. And the apply configuration still hangs.
You would have had to remove them from hosts and services, then run the verification again, and then move on to the next configuration file(s) that needed to be altered. Please provide a new:
It is going to be telling you what you need to change..
I rerun /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios and get the following messages. Did I do something wrong?
Nagios Core 3.5.0
License: GPL
Error: Cannot open main configuration file '/usr/local/nagios/etc/nagios' for reading!
Error processing main config file!
***> The name of the main configuration file looks suspicious...
Make sure you are specifying the name of the MAIN configuration file on
the command line and not the name of another configuration file. The
main configuration file is typically '/usr/local/nagios/etc/nagios.cfg'
]0;root@sm5nag01:~[root@sm5nag01 ~]#
Nagios Core 3.5.0
License: GPL
Looks like the verification command posted by Sam got truncated. Try:
Here's the rerun, I don't see 'Ironmail-CT1' in hostgroup at all in the web console:
[root@sm5nag01 ~]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.5.0
License: GPL
Error: Could not find any host matching 'Ironmail-CT1' (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 41)
Error: Could not expand members specified in hostgroup (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 41)
[root@sm5nag01 ~]#
Nagios Core 3.5.0
License: GPL
[root@sm5nag01 ~]#
You need to remove the host declaration "Ironmail-CT1" from any hostgroups or recreate the "Ironmail-CT1" host.nanz28v wrote:Error: Could not find any host matching 'Ironmail-CT1' (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 41)
