nagiosxi stuck at applying configuration
We had this issue with version 2012R2.1 after waking NagiosXI server up from a previous evaluation in January 2013. After we started the server in GUI we can no longer apply the configuration. It just say this forever:
Command submitted for processing...
Waiting for configuration verification.........................................................
We just updated to 2012R2.7 this morning and still the same issue. I'm a newbie to Linux that's why we went with NagiosXI for its GUI interface. Please let me know if I need to run some command to troubleshoot. Thank you.
Re: nagiosxi stuck at applying configuration
Lets start by checking the httpd error log. Run the following tail and while it is running try to apply configuration, wait a few minutes and kill the tail (ctrl-c), and then post the output:
tail -f /var/log/httpd/error_logFormer Nagios employee
Can you successfully write and verify config files? Configure > CCM > Tools > Write Config Tool. Click the buttons from top to bottom, and share the output please. Also show the output of:
cat /etc/php.ini | grep timeout
cat /etc/php.ini | grep memoryRe: nagiosxi stuck at applying configuration
Abrist, thank you for your input, here's the putty log according to your instruction:
Since my message contains too many URLS, I removed all expect one as below. It loops from PHP line 105 to 120. Please see attached log for full view. Thanks.
Last login: Tue Jan 7 15:52:36 2014 from 10.31.100.167
]0;root@sm5nag01:~[root@sm5nag01 ~]# tail -f /var/log/httpd/error_log
[Tue Jan 07 15:56:08 2014] [error] [client 10.14.225.50] PHP Notice: Undefined index: avg_latency in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 107, referer: http://10.14.133.60/nagiosxi/includes/c ... -index.php
[Tue Jan 07 15:56:08 2014] [error] [client 10.14.225.50] PHP Notice: Undefined index: min_execution_time in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 108, referer: http://10.14.133.60/nagiosxi/includes/c ... -index.php
=====omitted many repeating PHP line errors=========
[Tue Jan 07 15:56:28 2014] [error] [client 10.14.225.50] (13)Permission denied: access to /nagiosxi/includes/js/d3/d3.v3.min.js denied, referer: http://10.14.133.60/nagiosxi/includes/c ... config.php
Judging from your error log, you may be having problems with php.ini limits. What is the output of:
grep "memory_limit\|max_execution\|max_input" /etc/php.iniFormer Nagios employee
Slansing, thank you for your response. I can write to config files but when I tried to verify it I got these error messages:
I'm posting your GREP results at the very bottom of this post. Thanks.
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 115.
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Warning: Duplicate definition found for timeperiod 'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 114)
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.01.07 16:07:59 =~=~=~=~=~=~=~=~=~=~=~=
login as: root
NOTICE TO USERS
This system is the propery of MVP Healthcare. Access and use is for
MVP Healthcare authorized users only and is subject to monitoring by systems
personnel. Unauthorized access is a violation of Federal and State law and
will be prosecuted to the full extent of the law
[email protected]'s password:
Last login: Tue Jan 7 15:56:22 2014 from 10.31.100.167
]0;root@sm5nag01:~[root@sm5nag01 ~]# cat /etc/php.ini | grep timeout
; Default timeout for socket based streams (seconds)
default_socket_timeout = 60
; Maximum time (in secondes) for connect timeout. -1 means no limit
mysql.connect_timeout = 60
; Connect timeout
;mssql.connect_timeout = 5
; Query timeout
;mssql.timeout = 60
; Default timeout in seconds.
pfpro.defaulttimeout = 30
]0;root@sm5nag01:~[root@sm5nag01 ~]# cat /etc/php.ini | grep memory
memory_limit = 128M ; Maximum amount of memory a script may consume
; If this parameter is set to Off, then memory leaks will not be shown (on
; keeping them in memory.
Nagios Core 3.5.0
License: GPL
login as: root
NOTICE TO USERS
; Connect timeout
; Query timeout
;mssql.timeout = 60
Abrist, here is the output from Putty for command:
max_execution_time = 30 ; Maximum execution time of each script, in seconds
max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
You may want to increase (double) those values from php.ini and then restart httpd. But the crux of your issues are the config errors. Could you PM me your profile.zip? (admin --> system profile --> download)
I'm new to Linux, how do I increase (double) those values from php.ini specifically in commands? Thank you.
I get these errors when trying to generate profile.zip:
PROFILE BUILD FAILED
Array
CODE: 126
Array
CODE: 126
1) How many hosts and services do you have configured in XI currently?
2) The duplicate warning is due to some changes in the XI templates. Can you attach the following files to your next post (you may need to use filezilla/winscp to download the files):
3) To increase the php limits, you need to edit the values in /etc/php./ini. You can use the cli editor "nano" to do so:
Scroll down to each of the values and change:
To:
Save out with "ctrl-o" and then exit with "crtl-x".
/usr/local/nagios/etc/timeperiods.cfgCode: Select all
nano /etc/php.ini
[snip]
[snip]
memory_limit = 128M ; Maximum amount of memory a script may consumeCode: Select all
max_execution_time = 60 ; Maximum execution time of each script, in seconds
[snip]
max_input_time = 90 ; Maximum amount of time each script may spend parsing request data
[snip]
memory_limit = 256M ; Maximum amount of memory a script may consumeFormer Nagios employee
