How to monitor the bandwidth usage of a Windows host?
Noctis0791
Re: How to monitor the bandwidth usage of a Windows host?
Post by Noctis0791 »
Cool! That gives a valid result. :) So the check_nt seems to be working. What could be the problem with that check_win_net_usage plugin?
Thank You,
Arnel
I'm glad your issue has been resolved!
This is a third party plugin. We haven't tested it and we cannot guarantee that it is going to work well with Nagios. You will need to contact the developer of the plugin.
Post by slansing »
I will try aside some time to test it here today, but contacting the developer of it would be a good idea. It looks like it is just a wrapper script for what you just ran, essentially.
abrist
Red Shirt
Post by abrist »
Additionally, the only test output from the plugin check_win_net_usage on the previous page had you checking "Test-PC" instead of the ip.
Noctis0791
Hi Guys,sorry for my late response. Okay, we'll try to contact its developer.
@ lmitchev - No problem I understand.
@ slansing - Were you able to test this plugin out?
@ abrist - "Test-PC" will also resolve to its ip address so I think either is fine.
Thanks guys,
Arnel
Post by slansing »
Sounds good, yeah that would probably be the best bet at this point, let us know if you need further assistance from our end.
abubakar08281
Post by abubakar08281 »
I am also using same script to monitor the network usage on windows servers and output is fetched as expected but graph is shown in only Bytes but this i am not expecting even after selecting -o KB
Please refer the attached snapshots and suggest me ,how i can modify the graph to display in KB
You will have to delete the xml and rrd files associated to that service so it will get rebuilt using the new performance output in KB.
