Running XI on Windows 7
sreinhardt
- -fno-stack-protector
Re: Running XI on Windows 7
hmm, I will have to install and test this, seems that you are using 32bit virtual pc and i686(32bit) XI, so this should be working, however it clearly is not. I will post back once I've had a chance to run through it.
By chance did you find anything out that I'm doing wrong? I'm researching getting a linux server in place as well.
What's the RAM set to? Should be 1G, but I just want to confirm. Might wanna increase that.
Found the setting! That worked, loading now...
Now it's continuing to loop through with the message
"Clocksource tsc unstable (delta = xxxxx ns). Enable clocksource failover by adding clocksource_failover kernel parameter."
Any thoughts there?
Any thoughts there?
Great to hear! We'll keep this thread open for a bit in case you have any more related questions, otherwise if it's working for you we can close it now.
Any thoughts there?
Any thoughts there?
Just Googling around here, but this might help: http://liquidat.wordpress.com/2013/04/0 ... ed-centos/
Thank you, I'll check that out.
Let us know if you have questions!
Still no luck. I thought it might have been a download issue as I saw a "corrupt" message fly by. Downloading a new copy I tried again, increased memory to 1.5 and now it just sits there with the following message. And the caps lock keeps turning on and off. There was a colored status bar prior to this message and it looked promising...not so much.
Kernel panic - not syncing : attempted to kill init!
Pid: 1, comm: init Not tainted 2.6.32-358.2.1.el6.i686 #1
Call Trace:
[] ? panic...
[] ? do_exit....
[] ? do_group_exit....
[] ? sys_exit_group....
[] ? sysenter_do_call ....
As this has been a key directive from my leadership and I need to get it up and running, I'm getting a Linux server built and then going through the manual install there. I'm hoping I have better success.
Call Trace:
[] ? panic...
[] ? do_exit....
