Storage Physical Disk utilization
Re: Storage Physical Disk utilization
Can you show us the output of the plugin? What do you have to the right of the pipe ("|")? Does the plugin return the correct output?
http://docs.pnp4nagios.org/pnp-0.6/perfdata_format
murali969
Post by murali969 »
The error is as below
XML file "/var/lib/pnp4nagios/perfdata/hp-eva-01/EVA_Disks_Status.xml" not found. Read FAQ online.
Please help on this.
Murali Muppa
abrist
Red Shirt
Post by abrist »
We would like to see the output of the check. Go to --> Services --> click on the service in question. What is the output for the line "Performance Data" from the details table?
murali969
Post by murali969 »
I got error as below
Please check the documentation for information about the following error.
XML file "/var/lib/pnp4nagios/perfdata/hp-eva-02/EVA_Disks_Status.xml" not found. Read FAQ online
file [line]:
abrist
Red Shirt
Post by abrist »
Is it reporting that error in the "Performance Data" table cell?
murali969
Post by murali969 »
Still it is getting error
abrist
Red Shirt
Post by abrist »
The check itself may not have performance data. Can you post the output of the check when run from the cli?
And please find the following page for your disk check service, take a screenshot, and include it in your post:
chris.fixter
Post by chris.fixter »
I could be wrong. I thought Murali wanted a service definition that will check the "total used the capacity of disks", like the 2nd and 8th service in the screen.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
I don't think you're necessarily wrong, I just don't think it has been explained very clearly. From the thread, it sounds like he wants graphing, but reading his initial post it could absolutely be graphing or a second check for this. Murali, clarification is needed on what exactly you wish to setup, are you looking for an additional check for disk utilization or graphing of your existing checks?
