Storage Physical Disk utilization
murali969
Post by murali969 »
Hi All,
Can some one help me as below
I would like to configure in nagios to display the Storage disk utilization as well graphs.
My environment as below
Nagios server is Debian linux
Nagios version :Nagios® Core™
Version 3.2.1
Murali
Re: Storage Physical Disk utilization
Post by slansing »
Do you already have a graphing addon installed and set up such as pnp4nagios?:
http://docs.pnp4nagios.org/
If not, you will need to set that up, or use nagiosgraph which may be already installed.
I would start by adding the host, and the service you are trying to monitor. What type of system are you trying to monitor the disk metrics on, depending on this, you will be able to follow the "How to Monitor -----" sections in this contents page:
http://nagios.sourceforge.net/docs/3_0/toc.html
murali969
Post by murali969 »
I already configured HP 3par storage and monitoring and working fine.
I would like to see physical data performance(status :in terms of utilization)
Murali Muppa
jorr
Post by jorr »
What type of physical data performance?
Throughput, iops, latency, storage capacity utilization? Many of these can probably queried by utilizing SNMP requests to gather the data using check_snmp and routed back through pnp4nagios to generate graphs.
There may even be a plugin designed for your storage in particular. I was surprised with the availability of information on the storage systems I utilize.
Jesse
Post by slansing »
All very valid questions, let us know Murali, we're glad to help. I'd recommend taking a look at the first half of my initial reply, since it seems like you may have missed it. :)
murali969
Post by murali969 »
Hi Slansing,
I have already monitoring few storage devices like ping response,EVA controllers ,However would like to monitor storage capacity utilization.
I am not aware PNP4nagios.
Murali Muppa
Post by slansing »
If you are not familiar with it, go look at the link that I attached in my first post. Let us know if you have questions, I'd recommend using PNP4Nagios, it is quite reliable and does not have too steep of a learning curve.
murali969
Post by murali969 »
I have already nagios core 3.2 version configured few storage devices,however is pnp4nagios will change whole environment.
Would you please help me to configure nagios core 3.2 version.
Post by slansing »
That is quite a broad question, we really need more specifics from you in your questions...
PNP4Nagios will set up performance data handling for your checks, which will in turn display them on graphs if set up properly, that is all well documented in the link I sent you.
Once again, extremely broad... I highly recommend reading through these tutorials based on what you are doing:
When you run into problems we can help you out.
murali969
Post by murali969 »
HI Slansing,
I have configured pnp nogais and i have compiled ,updated & restarted.
When i refresh and checked it Nagios browser and as i got a below error
Please check the documentation for information about the following error.
XML file "/var/lib/pnp4nagios/perfdata/hp-eva-01/EVA_Disks_Status.xml" not found. Read FAQ online
Not found the EVA_Disks_Status.xml is there any chance to generate this file.
Murali Muppa
