Two identical services with different email behaviour
Re: Two identical services with different email behaviour
Lets run
ps -ef|grep bin/nagios
To make sure we don't somehow have an old nagios process running.
If that isn't the issue, I would grep the config directories for all occurrences of wachtdienst.blackberry to see how this could have been included...
WillemDH
Post by WillemDH »
Scott, I did it multiple times as I seem to have different results:
root@srv~]# ps -ef | grep bin/nagios
nagios   25513     1  1 17:10 ?        00:01:08 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27741 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27838 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27846 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27970 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27971 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27972 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27973 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27974 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27975 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27978 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27986 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27987 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27989 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27990 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27991 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27994 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   27996 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28041 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28043 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28045 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28046 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     28050  5748  0 18:09 pts/0    00:00:00 grep bin/nagios
[root@srv~]#     ps -ef|grep bin/nagios
nagios   25513     1  1 17:10 ?        00:01:09 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28240 25513  0 18:09 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     28513  5748  0 18:10 pts/0    00:00:00 grep bin/nagios
nagios   28646 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28648 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28649 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28650 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28652 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28653 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28654 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     28664  5748  0 18:10 pts/0    00:00:00 grep bin/nagios
nagios   28677 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28678 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28703 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28704 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28706 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28721 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   28723 25513  0 18:10 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     28726  5748  0 18:10 pts/0    00:00:00 grep bin/nagios
Nagios XI 5.8.1
https://outsideit.net
You don't have multiple instances of nagios running. These are all child processes.
Run the following command and show us the output:
grep -R -i "wachtdienst.blackberry" /usr/local/nagios/etc/
WillemDH
Post by WillemDH »
Ludmill,
I pm'd you the output of the command, as it contains some sensitive information.
Grtz
Nagios XI 5.8.1
Got it. Thanks! I sent you a PM.
WillemDH
Post by WillemDH »
This can be closed.
Nagios XI 5.8.1
