I was kind of surprised today that when submitting a passive OK result to a service state today, our on duty phone received an email whil the service wasn't configured to send emails to this on duty contact. After some research I still don't understand why this service is sending out emails to this contact.
In fact the service belongs to a cluster node and the exact same service on another node with exact the same config is not sending emails to this on duty contact when it's state changes... When I retried submitting critcal results, it aagin sent an email to a contact that is not defined in the service nor service template.
Config of the service and service template:
Service that does not send an email to on duty contact:
host_name clusternode02
service_description CLU_Cluster_Services_Events
use dig-windows-eventlog-cluster-prio1
servicegroups +all_svc_dummy_servicegroup
contacts +nagiosadmin
contact_groups +xi_dig_dummy_contact_group
_xiwizard windowseventlog
register 1
host_name clusternode01
register 1
}Code: Select all
name dig-windows-eventlog-cluster-prio1
display_name CLU_Cluster_Services_Events
servicegroups +all_crit_svc_win_cluster,all_svc_win_evt_cluster
check_command check_dummy!0!'Dummy check passed'!!!!!!
is_volatile 0
initial_state o
max_check_attempts 3
check_interval 1440
retry_interval 10
active_checks_enabled 0
passive_checks_enabled 1
obsess_over_service 0
check_freshness 0
event_handler_enabled 0
flap_detection_enabled 1
process_perf_data 0
retain_status_information 1
notification_interval 1440
first_notification_delay 0
notifications_enabled 1
stalking_options o,w,c,u,
register 0
I'm probably missing something?
Grtz
Willem
