Nagios is Frozen
sreinhardt
-fno-stack-protector
Re: Nagios is Frozen
Post by sreinhardt »
OH, so you have core 4 from source, and core 3.5 from rpm. I would highly suggest removing the core 3.5 rpm, then reinstalling (not upgrading) from scratch, short of plugins and configurations, you want to keep those and put them back in /usr/local/nagios/...
furqan
Post by furqan »
Thankyou, but i dont have any idea how to reinstall the core without upgrading it . i am a very new user of terminal and linux so please be kind in writing instructions.
i followed this step by step procedure to install nagios http://www.tecmint.com/install-nagios-in-linux/ and for upgrading it http://nagios.sourceforge.net/docs/3_0/upgrading.html
i will be very thankful to you :)
have a nice day and weekend
First of all, back up your /usr/local/nagios/etc/ directory with the following:
cp -r /usr/local/nagios/etc/ /root/nagios
run as the root user.
Then you should be able to run something like "yum remove nagios*" to uninstall the one that you installed via rpm. The actual name of the program might change depending on how it was installed initially so we include the * character to handle variations. Note that this will also remove the plugins.
Then you can safely remove the nagios directory with the following:
rm -rf /usr/local/nagios
again run as the root user.
From here you should have a mostly clean system and you can follow the install directions here:
http://assets.nagios.com/downloads/nagi ... Source.pdf
If you can afford to do so, a clean CentOS 6.5 install might not be a bad idea to make sure we have a known good base to install onto.
furqan
Post by furqan »
Thanks a lot .
i followed the procedure but i see that files and folders from old nagios are still there, and for me (begginer) its a a very complicated situation to diagnose and act .
my final option would be to uninstall everything including the OS, and reinstalling everything, but htis would be the final option because otherwise i will have to go through all the pain again :p
if there is any diagnosing procedure share please.
Please do not bump your questions, it creates needless clutter, and it also puts you lower on our "to be replied to list..."
Post by slansing »
What files and folders? If you ran 'rm -rf' against the nagios directory, they would be removed. Your nagios directory is /usr/local/nagios is it not?
furqan
Post by furqan »
sorry my misconfusion, you are right i have only single nagios instance , but the problem is i cant access the webpage.
error:404 not found
anyway i note that httpd service is not starting
abrist
Red Shirt
Post by abrist »
furqan wrote:anyway i note that httpd service is not starting
That will definitely be part of the problems. What is the full output when you try to restart the httpd process?
