acknowledge and disabled
equick
Re: acknowledge and disabled
Post by equick »
These are the service commands available to me in that helps?
Post by Box293 »
One other thing to try, you right click on the blue box "1 Disabled" (not the word/hyperlink but the blue box) and select inspect element. The send us the HTML code for that element as it should tell us what item it's related to.
equick
Post by equick »
Thanks, I hope this is what you meant
I believe those are due to the active checks being disabled. Try clicking the "Enable active checks of this service" link from the image you shared in your previous post.
equick
Post by equick »
These are passive checks though.
I understand that, but if you have an active check set up for freshness checking and you have active checks disabled, that might be what is causing the Disabled message. I looked into the Core source code and found very few mentions of that particular "serviceUnimportantProblem" string, so there is not a lot that could cause it. Try re-enabling the active and see if the message goes away. If you really need active disabled, then at the very least we know what the message means.
equick
Post by equick »
That seems to work although I'm not sure I understand what's going on now.
After clicking enable active checks, I see this screen asking to disable active checks:
But later if I go back to the service, it seems fine, although it reports this as an active check (which it isn't):
The console now displays an unhandled message which seems right :
Post by Box293 »
If you now go and disable it from being an active check, it is all OK now?
equick
Post by equick »
No it reverts back to disabled like this one:
Post by Box293 »
Can you please post the service configuration of the service.
