I could delete the directory as Nagios yes... but not the files inside of it. The file permissions, look at the screenshot in the first post, themselves are group r world r. Which means members of the nagios group can only read the file.
I could delete the webinject directory but that would nuke the plugin as well.
Can you show me your file permissions within the webinject directory?
Web Inject config files not removing
krobertson71
Re: Web Inject config files not removing
This is mine:
Do you not have the writable flag? Is there a umask on your system?
$ ls -l /usr/local/nagiosxi/etc/components/webinject/
total 72
-rwxrwxr-x 1 apache nagios 63271 Sep 30 22:06 webinject.pl
-rw-r--r-- 1 apache nagios 228 Nov 24 16:12 www_nagios_com__Web_Transaction_config.xml
-rw-r--r-- 1 apache nagios 94 Nov 24 16:12 www_nagios_com__Web_Transaction_testdata.xml
umaskFormer Nagios employee
krobertson71
ummmm I figured out my very stupid mistake...
I was trying to sudo rm.
Sorry been using sudo all day for other things unrelated.
I am so sorry for the wasted time.
