I removed the host google.com and applied configuration.
I had two of these where I was trying different things, but were removed with the same steps above.
When I go into /usr/local/nagiosxi/etc/components/webinject the files are still there even though they are no longer showing in CCM or under Hosts or Services from the Home screen.
-rw-r--r-- 1 apache nagios 224 Nov 23 12:49 google_com__Web_Transaction_config.xml
-rw-r--r-- 1 apache nagios 94 Nov 23 12:49 google_com__Web_Transaction_testdata.xml
-rwxrwxr-x 1 apache nagios 63271 Jun 10 16:52 webinject.pl
-rw-r--r-- 1 apache nagios 228 Nov 23 12:38 www_google_com__Web_Transaction_config.xml
-rw-r--r-- 1 apache nagios 196 Nov 23 12:38 www_google_com__Web_Transaction_testdata.xml
Bigger question is why these are not being removed when I remove them via CCM??
