(No output on stdout) stderr:
deepshikha20
Re: (No output on stdout) stderr:
Please find the attached .
Thanks.
Regards,
Deepshikha
Thanks.
Regards,
Deepshikha
resource.cfg- resource.cfg
- (1.31 KiB) Downloaded 611 times
nagios.cfg- nagios.cfg
- (44.74 KiB) Downloaded 640 times
Can you list the permissions of the plugins in the plugin directory defined
and
ls -la /usr/local/nagios/libexec
ls -la /usr/local/nagiosCode: Select all
chage -l nagios-
deepshikha20
hi,
PFA the output as requested.
Thanks.
Deepshikha
Thanks.
Deepshikha
permissions.txt- output
- (4.76 KiB) Downloaded 669 times
These look ok.
Does the nsclient.log have the "No data to return." for all the checks?
- Box293
- Too Basu
Can you also post your nsclient.ini file from your windows box.
deepshikha20
PFA as requested.
Thanks.
Regards,
Deepshikha
Thanks.
Regards,
Deepshikha
nsclient.ini- nsclinet.ini
- (6.94 KiB) Downloaded 659 times
nsclient.log- nsclient.log
- (3.47 KiB) Downloaded 579 times
- Box293
- Too Basu
I can't replicate your issue.
I've installed your version on a Windows 2008 R2 server and used your ini file. The only change I made was to "allowed hosts = ".
Lets turn on debugging and see what extra information you get.
[/settings/log]
Change
level = info
to
level = trace
Save the file and restart the NSClient service.
Force some immediate checks from Nagios and then send through the nsclient.log file.
- Open a command prompt
Type cd "\Program Files\NSClient++\" and press Enter
Type nscp settings --activate-module NSClientServer --add-defaults and press Enter
Type notepad "C:\Program Files\NSClient++\nsclient.ini" and press Enter
[/settings/log]
Change
level = info
to
level = trace
deepshikha20
I have restart the service and i have tried to do some force checks but didn't get any logs.
Please find the attached logs.
Thansk.
Deepshikha
Thansk.
Deepshikha
nsclient.log- (24.27 KiB) Downloaded 561 times
sreinhardt
- -fno-stack-protector
Could you post the current nsc.ini or nsclient.ini please?
deepshikha20
PFA.
nsclient.ini- nsclient.ini
- (12.12 KiB) Downloaded 590 times
