Here is a link to VMware's knowledge base talking about ESXi not reconnecting syslog if it lost connection to the remote server.
http://kb.vmware.com/selfservice/micros ... Id=2003127
VMware Logs not coming in
Re: VMware Logs not coming in
Yes, I know tgriep. Troy already posted that link.
It does not give any solution though, nor any update on when this issue would be solved. As in order to execute "esxcli [--server hostname --user username] system syslog reload" we have to enable ssh etc, login, I was hoping to work towards a solution where "esxcli [--server hostname --user username] system syslog reload" would be executed at the moment the problem arises. I suspect I could use the vma for that, but it's only used for the box293 plugin atm, so before I start looking into this option, I was hoping to hear Troy's opinion.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
Sorry, Missed Troy's post.
Are your server patched to the minimums that VMware recommends?
Well Tgriep, I'm sorry too. I thought we were on 5.5, but when execute ']vmware -vl' on the ESX server I added, I get
[code
VMware ESXi 5.1.0 build-2000251
VMware ESXi 5.1.0 Update 2[/code]
It seems we are on ESXi 5.1.0 build 2000251, which seems higher then the proposed build with the 'patch' for tcp:
vSphere ESXi 5.1 build 1483097 or higher. For more information, see VMware ESXi 5.1 Update 2 Release Notes.
But we still experience the issue...
Grtz
Willem
[code
Grtz
Willem
Nagios XI 5.8.1
I found this in VMware's article for ESXi 5.1
I looks like if you setup syslog to use UDP instead of TCP, it will reconnect automatically.After a network or storage interruption, syslog over TCP, syslog over SSL, and storage logging do not restart automatically.
After a network or storage interruption, the syslog service does not restart automatically in certain configurations. These configurations include syslog over TCP, syslog over SSL, and the interrupt storage logging.
Workaround: Restart syslog explicitly by running the following command:
esxcli system syslog reload You can also configure syslog over UDP, which restarts automatically.
Tgriep, that sounds like a nice plan.
So I reconfigured the syslog host to udp://<ip-naglog-server>:1514
The firewal settings on the esxi host was still correct, just like the iptables on the NLS.
But the syslog messages are not flowing in. I did a tcpdump port 1514 , but nothing to see. So I did another
one the esxi server, but still nothing.
I must be missing something, as tcp worked fine...
Did another
Rechecked firewall settings on the esxi host, udp 1514 is open...
Grtz
Willem
Did another
Type iptables -I INPUT -p tcp --destination-port 1514 -j ACCEPT and press Enter
• Type iptables -I INPUT -p udp --destination-port 1514 -j ACCEPT and press Enter
• Type service iptables save and press Enter Grtz
Willem
Nagios XI 5.8.1
Ok, I think I know why. UDP seems to use 514 by default in all the examples I saw. That will be it. I do some tests and will let you know.
Nagios XI 5.8.1
To do ports below 1024 on the log server, you will need to follow this document.
http://assets.nagios.com/downloads/nagi ... Server.pdf
Changed the LS_USER to root as described in http://assets.nagios.com/downloads/nagi ... erver.pdf
Restarted logstash service
tcpdumpport 514
And logs seem to flow in again. After applying config in global configuration, the logs were visible in NLS again.
Restarted the logstash service again and it seems the logs keep flowing in after the restart. Thanks Tgriep for the help! I'll add some more ESX servers tomorrow and will do some more tests and will let you know if the thread can- be closed.
Grtz
Willem
tcpdumpport 514
Grtz
Willem
Nagios XI 5.8.1
Keep us informed.
