VMware Logs not coming in
WillemDH
Post by WillemDH »
hello,
I've jsut installed our first Log Server instance. I followed this guide to get ESXi logs: http://assets.nagios.com/downloads/nagi ... Server.pdf but I don't see any logs coming in.
syslog.globalhost.loghost is set top tcp://ip-address:1514 and firewall port 1514 is open.
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
lgroschen
Re: VMware Logs not coming in
Post by lgroschen »
Did you apply config after adding the input into Log server?
Also, try this on your logserver machine:
netstat -nlp | grep 1514
/Luke
WillemDH
Post by WillemDH »
Hey Luke,
Gives no result.
I think I applied configuration, the "save" and the "save and apply" button is greyed out by the way.
Grtz
Willem
Nagios XI 5.8.1
Can you go to the Logserver's Global Configuration and verify that the Input you created for the ESXi server is active?
Can you run the following from a command line and post the output?
service iptables status
WillemDH
Post by WillemDH »
Luke,
Output iptables on the Nagios Log Server:
Table: filter
Chain INPUT (policy ACCEPT)
num  target     prot opt source               destination
1    ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0           udp dpt:1514
2    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           tcp dpt:1514
3    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:2057
4    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:2056
5    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:5544
6    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:3515
7    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpts:9300:9400
8    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:443
9    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:80
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
And see attached screenshot for view of the global configuration.
Seem correct right?
Grtz
Willem
Nagios XI 5.8.1
The attached screen shot never made it to the post, can you try adding it again?
Lets install tcpdump on the log server and see if the ESXi server is sending data to the log server.
Run these commands on the logserver.
yum -y install tcpdump
tcpdump port 1514
Let it run for a while to see if data is getting to the log server.
If you don't see any data, check the ESXi server's settings for syslog and the firewall to see if they are correct.
Post by Box293 »
If you see data coming in, they this may be a timezone configuration issue as I've come across similar problems recently.
Run this command:
ls -al /etc/localtime
Which will output something like:
lrwxrwxrwx 1 root root 39 Jun 26 2014 /etc/localtime -> /usr/share/zoneinfo/Australia/Melbourne
Make sure this is your correct timezone.
Run these two commands
date
hwclock
Make sure they have the same date/time.
Run this command:
cat /etc/php.ini | grep date.time
Make sure it has the correct timezone, in my example above it should be:
date.timezone = Australia/Melbourne
If you do change it restart the httpd service
service httpd restart
Run this command:
cat /etc/sysconfig/clock
Make sure it has the correct timezone, in my example it should be
ZONE="Australia/Melbourne"
If you change it, restart logstash
service logstash restart
Also, I've had issues where the syslog service on the ESXi hosts stops working when the Log Server goes offline (you might reboot it). After that it doesn't restart when the Log Server is back online. This VMware article points to a known issue and is fixed in later versions of ESXi. Check the link for detailed information:
http://kb.vmware.com/selfservice/micros ... Id=2003127
WillemDH
Post by WillemDH »
Hey,
Installed tcpdump and started listening on port 1514. It seems not much is flowing in.
lrwxrwxrwx 1 root root 35 Jan 26 16:43 /etc/localtime -> /usr/share/zoneinfo/Europe/Brussels
Date was ok:
date
Tue Jan 27 08:28:59 CET 2015
But hwclock was not:
hwclock
Tue 27 Jan 2015 07:27:15 AM CET  -0.306870 seconds
So I synced it with
hwclock --systohc
[root@srvnaglog01 ~]# hwclock
Tue 27 Jan 2015 08:28:35 AM CET  -0.931657 seconds
So that should be ok now.
PHP time:
; http://www.php.net/manual/en/datetime.configuration.php#ini.date.timezone
date.timezone = Europe/Brussels
ZONE="Europe/Brussels"
UTC=False
How frequent should an ESXi server write logs? Are these syslog messages the events in the task & events tab of an ESXi server?
I'll enable cli and check if the syslog daemon is running.
EDIT: It seems I was able to reload syslog :
~ # esxcli system syslog reload
~ # ps -Cuv | grep vmsyslogd
8666 8666 vmsyslogd /bin/python
Which would imply it was still running.
Grtz
Nagios XI 5.8.1
WillemDH
Post by WillemDH »
I think the command
must have kickstarted the daemon, as logs are coming in now. I hope the syslog daemon is not failing every time I restart the server..., as I have like 35 ESXi servers...
I'm not looking forward to enable cli and reload every time it fails.
Can I monitor the ESXi syslog service state with Nagios XI? And maybe make a Reactor Event Handler when it fails?
Grtz and thanks.
Willem
Nagios XI 5.8.1
WillemDH
Post by WillemDH »
Troy,
I did the test and indeed. After restarting the logstash service the logs stop flowing in from the ESXi server.
How would I best deal with this? Executing
Solved the problem again. We are on ESXi 5.5. I don't seem to find any patches for ESXi 5.5..
Grtz
Willem
Nagios XI 5.8.1
