In version 1.3 of NLS, there is an added panel to display scheduled jobs - under Administration --> System --> Command Subsystem.
I found the job ID not meaningful, but you can edit the Job to get the description of the System Job. I found this panel helpful to find when the next time a maintenance job will run. You can change the frequency, and the scheduled time for the next run (change it to time before current time to run immediate).
Traceback (most recent call last):
File "/usr/bin/curator", line 5, in <module>
from pkg_resources import load_entry_point
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 2655, in <module>
working_set.require(__requires__)
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 648, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 546, in resolve
raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: elasticsearch>=1.0.0,<2.0.0
However, my maintenance seems to be running fine after the 1.3 upgrade. The post earlier in the thread stating is was not working was some other guy hijacking the thread
I am very sorry. My intention was to avoid open another thread with the same subject because my backup schedule does not seem to work. I am sorry for this ljorg.
teirekos wrote:I am very sorry. My intention was to avoid open another thread with the same subject because my backup schedule does not seem to work. I am sorry for this ljorg.
Not at all, there's no problem other than the confusion of the Nagios support team
