Maintenance doesn't seem to run
Ive set maintenance to close any index older than seven days, but it doesn't do anything. I have to close indexes manually. It appears that with more than 130 million records (or so) the performance of Nagios Log Server crawls to a stop. Adding extra memory or cores doesn't seem to help, but closing old indexes helps tremendously.
My settings are shown in the attachment below
Re: Maintenance doesn't seem to run
Have you tried to configure the heap memory? Check the link below:
http://www.elasticsearch.org/guide/en/e ... izing.html
I agree with @teirekos about the heap memory.
Also can you run the following command and return the output
curl -XGET "http://localhost:9200/nagioslogserver/commands/_search?pretty&q=command:do_maintenance"
I'll get on top of that soon.scottwilkerson wrote:I agree with @teirekos about the heap memory.
This is the output:scottwilkerson wrote:Also can you run the following command and return the output
"took" : 9,
"timed_out" : false,
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 1,
"max_score" : 4.749504,
"hits" : [ {
"_index" : "nagioslogserver",
"_type" : "commands",
"_id" : "ZM65w-m1QFy9is8Ebkdw0w",
"_score" : 4.749504,
"_source":{"created":"2014-12-09 15:02:37","active":1,"status":"waiting","type":"system","node":"global","command":"do_maintenance","run_time":1423749939,"frequency":"86400","last_run_output":"Maintenance and Backup jobs are being executed","last_run_time":"2015-02-11 15:05:39","last_run_status":"SUCCESS"}
It appears to be running, it was last executed on "2015-02-11 15:05:39"
One thing to note, on some systems we have noticed a bug releated to the addon that processes these. You can determine if you are affected by these by running the following from the command line.
this bug will be resolved in the next release due out soon.
curatorRe: Maintenance doesn't seem to run
The output of curator:
Does that mean I'm affected and is that why maintanence doesn't work although it runs?
Lars
Traceback (most recent call last):
File "/usr/bin/curator", line 5, in <module>
from pkg_resources import load_entry_point
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 2655, in <module>
working_set.require(__requires__)
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 648, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 546, in resolve
raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: elasticsearch>=1.0.0,<2.0.0
Lars
How did you install this server? One of our pre-built VMs, or did you use fullinstall on an existing server? It almost looks like python was already installed. What version is it?
python --versionFormer Nagios employee
It's installed on a RedHat Enterprise Linux 6. Python is probably installed by default. It's version 2.2.6.
Lars
Lars
Nagios Log Server 1.3 came out yesterday which has a fix for this problem.
http://library.nagios.com/library/produ ... /downloads
I've installed NLS 1.3 I left it all the weekend and still no snapshots created.
