Bulk Modification Tool Contact Group or Contact
Re: Bulk Modification Tool Contact Group or Contact
Shouldn't be necessary but thank you.
Let us know if you are still having issues after the upgrade.
I've upgraded them all to Nagios XI 2014R2.6. The tool works fine now.... But now I am getting complaints from folks that critical alerts are being received flagged as high priority. Is there a way to turn this off?
This was added in 2.6. I don't believe there is a ui switch for this. You can edit the following file:
At line # 91, comment out (or remove) this block of code:
This change will need to be performed after each upgrade. If you wish us to add a ui option to disable this, please open a feature request on the tracker: http://tracker.nagios.com
/usr/local/nagiosxi/html/includes/utils-email.inc.phpCode: Select all
if (isset($opts["type"]) && $opts["type"] == "PROBLEM") {
// For most clients expecting the Priority header:
// 1 = High, 2 = Medium, 3 = Low
$mail->Priority = 1;
// MS Outlook custom header
// May set to "Urgent" or "Highest" rather than "High"
$mail->AddCustomHeader("X-MSMail-Priority: High");
// Not sure if Priority will also set the Importance header:
$mail->AddCustomHeader("Importance: High");
}Former Nagios employee
Thanks. Please feel free to close this.
