Can't Acknowledge or Schedule Down Time (Not Authorized)
Re: Can't Acknowledge or Schedule Down Time (Not Authorized)
Can you try going to the Admin->Reset Security Credentials page and resetting the backend credentials. Is the username displaying correctly in the XI interface (top right)?
The user name is displaying correctly in the upper left corner. I reset the backend credentials and this did not resolve the problem.
I would have responded sooner, but I did not realize that your post was on page 2. I figured it out when I posted a "Are you There" and it appeared on page 2 behind your post. If you got the "Are You There" post disregard it as I am being an idiot.
espint,
Can you navigate to the the actual Nagios Core page?
http://<yourserver>/nagios
Do you have to log in to view the page? Or does it just display the page without asking for login details?
Nicholas Scott
I can not login to [myserver]/nagios I get the webpage cannot be found error. http 404
Is your apache running? Try:
Are you suing the right IP address for your Nagios server?
# service httpd statusBe sure to check out our Knowledgebase for helpful articles and solutions!
httpd is running... and I confirmed is with the command. I am certain I'm using the right IP address. Most of NagiosXI is working but just these few things. I get text message and e-mail alerts as I should. Passive Event Log services also work great. Google map and Hyper map work fine. I monitor 54 hosts 273 services with no other issues except that my boss has also informed me that he cant get any reports to function. All these things worked a few versions ago, should I consider rolling back to an earlier version. I'm on 2011R1.6 Thanks.
Can you show us the contents of your /etc/httpd/conf.d/nagios.conf file, and also verify that the /usr/local/nagiosxi/etc/htpasswd.users file has at least the nagiosadmin username in it?
I am sorry this is becoming so drawn out. I have a lot of projects going. The /usr/local/nagiosxi/etc/htpasswd.users file has noagiosadmin username in it, as well as all my other usernames.
Thanks for your help.
The contents of my /etc/httpd/conf.d/nagios.conf file is as follows:
# SAMPLE CONFIG SNIPPETS FOR APACHE WEB SERVER
# Last Modified: 11-26-2005
# This file contains examples of entries that need
# to be incorporated into your Apache web server
# configuration file. Customize the paths, etc. as
# needed to fit your system.
#NameVirtualHost *:443
<VirtualHost *:80> # Add this line
<Directory "/usr/local/nagiosxi/html">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "Nagios XI"
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
# Require valid-user
</Directory> # Add this line
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile /etc/pki/tls/certs/nagiosxi.espint.com.crt
SSLCertificateKeyFile /etc/pki/tls/private/nagiosxi.espint.com.key
AllowOverride All
</Directory>
</VirtualHost>
Alias /nagiosxi "/usr/local/nagiosxi/html"
# SSLRequireSSL
Options ExecCGI
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
AuthName "Nagios Core"
AuthType Basic
Require valid-user
</Directory>
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
AllowOverride All
</Directory>
</VirtualHost>
# SSLRequireSSL
Options ExecCGI
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
AuthType Basic
Require valid-user
</Directory>
In your /usr/local/nagios/etc/cgi.cfg file, do you have a line that reads?
Did you follow this document while configuring ssl?
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
use_ssl_authentication=1http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
Good Morning. my/usr/local/nagios/etc/cgi.cfg file does contain a line that reads use_ssl_authentication=1
I did follow the document Configuring_SSL_with_Nagios_XI.pdf
XI logon screen goes blank when I do this step from the configuration document:
Now we will need to edit some Nagios XI files. First thing we'll start off with is editing /usr/local/nagiosxi/html/config.inc.php. Open
that file in a text-editor and add this line under $cfg['base_url']=”/nagiosxi”;
$cfg['use_https']=true;
If I remove this line I can use XI with http or https. I notice that the Nagiosxi.conf file is not like the one in the ssl configuration document, so I have change it to match. Both problems still exist, I can't enter any username fields in XI and https is not required. Are these two tied together somehow. The Certificate nagiosxi.espint.com.crt and the Key nagiosxi.espint.com.key do exist in the directory specified in the nagios.conf file. These are certificates from GoDaddy.
The nagios.conf file now reads:
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
AllowOverride All
</Directory>
</VirtualHost>
NameVirtualHost *.443
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
AllowOverride All
</Directory>
</VirtualHost>
