Can't Acknowledge or Schedule Down Time (Not Authorized)
espint
Post by espint »
Whenever we try to acknowledge a service problem or schedule down time the Author (Your Name) field comes up blank and will not let you enter anything. As a result, acknowledging a service problem or scheduling downtime fails. The error for either command is: "Sorry, but you are not authorized to commit the specified command. Read the section of the documentation that deals with authentication and authorization in the CGIs for more information." Should the field be editable or should it populate from the login credentials. I get this error with all user logons including nagiosadmin. Thanks in advance for your help.
I have Nagios XI 2011R1.6 installed on CentOS 5.5'
The results of commands
[root@monsrv003 ~]# service mysqld restart
Stopping MySQL: [ OK ]
Starting MySQL: [ OK ]
[root@monsrv003 ~]# service postgresql restart
Stopping postgresql service: [ OK ]
Starting postgresql service: [ OK ]
[root@monsrv003 ~]#
Re: Can't Acknowledge or Schedule Down Time (Not Authorized)
Run in terminal as root:
/usr/local/nagiosxi/scripts/reset_config_perms
Go to "Admin" menu and click on "Reset Security Credentials" under "System Config" from the left panel menu. Enter a new Config Manager Admin Password and click on "Update Credentials".
Also, click on "Check File Permissions" under "Monitoring Config" to check for permission issues.
Hope this helps.
espint
Post by espint »
Thanks for the quick reply.
I ran in terminal as root, the result was:
SETUPID ROOT OK
RESETTING PERMS
Reset the security Credentials: Security credentials updated successfully.
Checked the File Permissions this is the result:
Config File Permissions Check
Config Scripts
The permissions on the Nagios XI configuration scripts appear to be okay.
Config Files
The permissions on the Nagios Core configuration files to be okay.
Can you schedule a downtime or acknowledge a problem now?
espint
Post by espint »
No, nothing changed after followint those steps and I did not have any errors.
Can you run the following command in terminal and post the output?
# ls -l /usr/local/nagios/var/rw/nagios.cmd
espint
Post by espint »
Here are the results of the command:
[root@monsrv003 ~]# ls -l /usr/local/nagios/var/rw/nagios.cmd
prw-rw---- 1 nagios nagcmd 0 Sep 9 10:03 /usr/local/nagios/var/rw/nagios.cmd
[root@monsrv003 ~]#
Thanks.
Are you using LDAP or Active Directory components?
espint
Post by espint »
I am not using LDAP or Active Directory components. I have been working on SSL but have not managed to make that fully functional. I wonder if the two could be related?
espint
Post by espint »
When I get to the acknowledge page, the "logged in as" information in the upper left corner shows a "?". I have attached a snipit of this. The Author (Your Name) field on this same page will not let me click in it or add text in any way.
