Nagios 4.1.0-rc1 "Trends Report"
ssax
Dreams In Code
Re: Nagios 4.1.0-rc1 "Trends Report"
Post by ssax »
That is the classic theme, installed with "make install-classicui", the white one can be installed with "make install-exfoliation"
Please post the output of this command:
ls -l /usr/local/nagios/share/js/
Are you seeing any javascript errors?
nagtech2
Post by nagtech2 »
Oh, I was not aware of that.
-rw-rw-r-- 1 nagios nagios 1868 Mar 27 06:50 histogram-events.js
-rw-rw-r-- 1 nagios nagios 4293 Mar 27 06:50 histogram-form.js
-rw-rw-r-- 1 nagios nagios 11261 Mar 27 06:50 histogram-graph.js
-rw-rw-r-- 1 nagios nagios 3694 Mar 27 06:50 histogram.js
-rw-rw-r-- 1 nagios nagios 93868 Mar 27 06:50 jquery-1.7.1.min.js
-rw-rw-r-- 1 nagios nagios 13926 Mar 27 06:50 jsonquery.js
-rw-rw-r-- 1 nagios nagios 89053 Mar 27 06:50 map-directive.js
-rw-rw-r-- 1 nagios nagios 1541 Mar 27 06:50 map-form.js
-rw-rw-r-- 1 nagios nagios 4403 Mar 27 06:50 map.js
-rw-rw-r-- 1 nagios nagios 1581 Mar 27 06:50 nagios-decorations.js
-rw-rw-r-- 1 nagios nagios 5680 Mar 27 06:50 nagios-time.js
-rw-rw-r-- 1 nagios nagios 4563 Mar 27 06:50 trends-form.js
-rw-rw-r-- 1 nagios nagios 18093 Mar 27 06:50 trends-graph.js
-rw-rw-r-- 1 nagios nagios 6449 Mar 27 06:50 trends.js
ssax
Dreams In Code
Post by ssax »
I get the same screen that you get when I disable javascript, you don't have javascript disabled do you? Or see any javascript errors?
nagtech2
Post by nagtech2 »
I have 2 systems, 1 a production system running Ubuntu 12.04 LTS and Nagios 4.08 and the other test system which is running the new 4.1 which we have been talking about. Trends work fine on this browser when accessing my 4.08 image, but not in the test system image. Trend did work on the test system when it was running 4.08, after the upgrade it's broken. I don't see any java errors but I agree, has to be some sort of java issue.
Actually there was a bug in the RC1 Beta, causing this exact problem.
I believe it has already been fixed in master and will be pulled into the full release.
nagtech2
Post by nagtech2 »
Oh ok, Thanks for the info
Are we alright to close this thread? I don't have a roadmap for the next Core release unfortunately.
nagtech2
Post by nagtech2 »
Yeah that's fine thank you!
