In your post, I can see you had issues with mail delivery since you were not sending the emails from a valid domain name. My case is different. I do have a valid domain name though I masked it with another name here in the public post. I am able to receive alerts such as flapping alerts and the mail issue is only with disk alerts for certain hosts. I have copied the service definition of those in my first post.
As jdalrymple said, I checked the notification section and i couldnt see the service entry there. So I am concerned that it is something else. I am pasting configuration of that host again if you need.
use generic-host_dd ; Name of host template to use
host_name test1
alias Production server1
address IP
hostgroups teste-Server
use generic-service_dd ; Name of service template to use
host_name test1
service_description Disk Space
check_command check_nrpe_1arg!check_hda1
# check_command check_all_disks!20%!10%
}Thanks,
G
