Alerts generating for "DataFile IO Traffic"
wiproltdwiv
Re: Alerts generating for "DataFile IO Traffic"
Yeah, i have done that also but no use.
Please suggest me an other way to resolve this issue.
Could you go to the Core Config Manager, select one of the services that are still sending Notifications, Click the View Text Config icon, "The Floppy Disk", copy the settings and post it here?
wiproltdwiv
I have gone through that bulk modifications also,but i haven't found any effects.
Could you PM me the following file from your Nagios XI server?
/usr/local/nagios/var/objects.cacheBe sure to check out our Knowledgebase for helpful articles and solutions!
wiproltdwiv
# Service configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2015-05-12 10:37:33
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
host_name agraccb
service_description /archagraccb usage
use xiwizard_nrpe_service
check_command check_nrpe!check_archagraccb!!!!!!!
max_check_attempts 2
check_interval 15
retry_interval 1
check_period 24x7
notification_interval 60
notification_period 24x7
notification_options w,c,u,
register 1
host_name agraccb
service_description /findata1agraccb usage
check_command check_nrpe!check_findata1agraccb!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description /finidx1agraccb usage
check_command check_nrpe!check_finidx1agraccb!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description /oraagraccb usage
check_command check_nrpe!check_oraagraccb!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Alert Log File Usage
check_command check_nrpe!check_alert_agraccb.log!!!!!!!
max_check_attempts 5
check_interval 1440
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Datafile IO Traffic
use xiwizard_oracleserverspace_service
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode datafile-io-traffic --warning 1000 --critical 5000!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
notifications_enabled 0
contacts nagiosadmin
_xiwizard oracleserverspace
register 1
host_name agraccb
service_description Datafile Status
check_command check_nrpe!check_agraccb_par3!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Index Status
check_command check_nrpe!check_agraccb_par1!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Instance Status
check_command check_nrpe!check_agraccb_par5!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Invalid Objects
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode invalid-objects!!!!!!!
check_interval 1435
retry_interval 1
check_period 24x7
first_notification_delay 0
register 1
host_name agraccb
service_description Listener log file Usage
check_command check_nrpe!check_listener_agraccb.log!!!!!!!
check_interval 1440
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description mman
check_command check_nrpe!check_ora_mman_agraccb!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description mmon
check_command check_nrpe!check_ora_mmon_agraccb!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description PGA In Memory Sort Ratio
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode pga-in-memory-sort-ratio --warning 80: --critical 60:!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
notification_interval 0
register 1
host_name agraccb
service_description pmon
check_command check_nrpe!check_ora_pmon_agraccb!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Process Limit Usage
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode process-usage --warning 85 --critical 95!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Redo I/O Traffic
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode redo-io-traffic --warning 190 --critical 200!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Retry Ratio
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode retry-ratio --warning 1 --critical 10!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Seg Top 10 Logical Reads
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode seg-top10-logical-reads --warning 1 --critical 9!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Seg Top 10 Physical Reads
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode seg-top10-physical-reads --warning 1 --critical 9!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Seg Top10 Buffer Busy Waits
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode seg-top10-buffer-busy-waits --warning 1 --critical 9!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Seg Top10 Row Lock Waits
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode seg-top10-row-lock-waits --warning 1 --critical 9!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Session Limit Usage
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode session-usage --warning 85 --critical 95!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description SGA Data Buffer Hit Ratio
check_command check_xi_oracleserverspace! --connect "agraccb" --username gsmcinq --password "gsmcinq" --mode sga-data-buffer-hit-ratio --warning 95: --critical 85:!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description SGA Dictionary Cache Hit Ratio
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode sga-dictionary-cache-hit-ratio --warning 95: --critical 85:!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
contacts support
register 1
host_name agraccb
service_description SGA Latch Hit Ratio
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode sga-latches-hit-ratio --warning 80: --critical 60:!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description SGA Shared Pool Free
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode sga-shared-pool-free --warning 15: --critical 10:!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description SGA Shared Pool Reload Ratio
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode sga-shared-pool-reload-ratio --warning 90: --critical 70:!!!!!!!
check_interval 15
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description smon
check_command check_nrpe!check_ora_smon_agraccb!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Tablespace status
check_command check_nrpe!check_agraccb_par2!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description Tablespace Usage
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode tablespace-usage --warning 85 --critical 90!!!!!!!
check_interval 30
retry_interval 1
check_period 24x7
register 1
host_name agraccb
service_description TNSPing
check_command check_xi_oracleserverspace!--connect "agraccb" --username gsmcinq --password "gsmcinq" --mode tnsping!!!!!!!
check_interval 10
retry_interval 1
check_period 24x7
register 1
# END OF FILE
wiproltdwiv
Please find the below Ping results.
[root@EMSNagios1 ~]# /usr/local/nagios/var/objects.cache
-bash: /usr/local/nagios/var/objects.cache: Permission denied
jdalrymple
- Skynet Drone
wiproltdwiv - what we think is happening here is that your service is defined for each individual host. In order to disable notifications you have to disable it within this service for all hosts, or change an upstream template.
Can you do this?
- Go into Core Configuration Manager services:
Configure --> Core Configuration Manager --> Monitoring --> Services
- In the Search box type "DataFile IO Traffic"
- Click Search
- Count the number of results
In my screenshot the number we're seeking is 3. How many do you have?
Can you do this?
- Click Search
wiproltdwiv
We have 104 services for the "Datafile Io Traffic" Parameter.
wiproltdwiv
Dear Team,
We have disabled the notifications within this service only for all Hosts.
- Box293
- Too Basu
To do all 104 services you could use the Bulk Modifications Tool:
CCM > Tools > Bulk Modifications.
Does this help, or have you already resolved this?
