rhassing
Posts: 416 Joined: Sat Oct 05, 2013 10:29 pm
Post
by rhassing » Wed May 13, 2015 7:25 am
what happens if you'd do:
# 'check_mem_win' command definition
command_name check_mem_win
command_line $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ -C public -m ^[P] -w 90 -c 95
Rob Hassing
xerez
Posts: 77 Joined: Wed Apr 22, 2015 7:50 am
Post
by xerez » Wed May 13, 2015 7:43 am
It works too: Physical Memory: 54%used(692MB/1278MB) (<90%) : OK
But the arguments passed for windows.cfg still not work:
host_name <host name>
service_description Memory Usage
# check_command check_nt!MEMUSE!-w 90 -c 95
check_command check_mem_win!80!85
rhassing
Post
by rhassing » Wed May 13, 2015 7:48 am
Than you should change it as follows:
command_line $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ -C public -m ^[P] -w $ARG1$ -c $ARG2$
Rob Hassing
xerez
Post
by xerez » Wed May 13, 2015 8:04 am
Works perfect! Thanks you very much!
Now I will like try with NRPE. I hope that you help me with that error:
CHECK_NRPE: Error - Could not complete SSL handshake.
If in nsclient.ini I change:
To:
And I execute:
nagios@localhost:/usr/local/nagios/libexec$ ../../libexec/check_nrpe -H <host ip> -n
I (0.4.3.131 2015-02-15) seem to be doing fine...
Works!
I need anything in Windows for it works with SSL?
Thanks!
Posts: 9191 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Wed May 13, 2015 4:06 pm
Under this section
[/settings/NRPE/server]
Make sure these settings are there.
use ssl = true
allowed ciphers = ADH
Be sure to check out our
Knowledgebase for helpful articles and solutions!
jolson
Attack Rabbit
Posts: 2560 Joined: Thu Feb 12, 2015 12:40 pm
Post
by jolson » Wed May 13, 2015 4:08 pm
tgrieps answer is likely correct. Here is a working example nsclient.ini file for comparison:
[/settings/default]
allowed hosts = nagios.server.ip.address
password = somepass
[/modules]
NSClientServer = 1
CheckSystem = 1
CheckDisk = 1
NRPEServer = 1
CheckExternalScripts=enabled
use ssl = 1
payload length = 1024
allow nasty characters = false
ssl = 1
allow arguments = 1
insecure = 1
Twits Blog
xerez
Post
by xerez » Thu May 14, 2015 3:17 am
The configuration of jolson works perfect. I tried commenting and uncommenting the options of [/settings/NRPE/server] and finally, I needed add:
use ssl = true
And comment:
Thanks!!
jolson
Attack Rabbit
Post
by jolson » Thu May 14, 2015 9:36 am
xerez,
No problem. Would it be fine if we locked this thread?
Twits Blog
xerez
Post
by xerez » Mon May 18, 2015 3:21 am
Yes, thanks for your help!
