Why Nagios shows more memory than the real?
I have a host with 1.25 GB RAM, but Nagios shows that this host has 2668,87 Mb. I tried with other host and the result also was greater than real memory. Why? How solve it?
Thanks.
Thanks.
Re: Why Nagios shows more memory than the real?
Which plugin are you using to check the memory?
Rob Hassing
I use check_nt v2.0 (nagios-plugins 2.0):
check_command check_nt!MEMUSE!-w 80 -c 90Re: Why Nagios shows more memory than the real?
I'm currently using the following script:
http://nagios.manubulon.com/snmp_storage.html
This is using the information via snmp instead of running software on all servers.
check_snmp_storage.pl -C public -H 10.10.10.1 -m ^[P] -w 97 -c 98Rob Hassing
Mmm I execute this:
And the output is:
./check_snmp_storage.pl -C public -H <host ip> -m ^C: -w 97 -c 98Code: Select all
Argument "v6.0.1" isn't numeric in numeric lt (<) at ./check_snmp_storage.pl line 420.
ERROR: Description/Type table : No response from remote host "<host ip>".Re: Why Nagios shows more memory than the real?
What happens if you do:
snmpwalk -v2c -c public <host ip> 1.3.6.1.2.1.25.2.3.1Rob Hassing
@xerez
This is a known issue with NSClient++ and check_nt with MEMUSE. Try using check_nrpe instead.
If you define an alias in the nsclient.ini under [/settings/external scripts/alias], for example:
you could just run (from Nagios)
/usr/local/nagios/libexec/check_nrpe -H x.x.x.x -p 5666 -c CheckMEM -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
OK: physical: Total: 15.958GB - Used: 7.027GB (44%) - Free: 8.931GB (55%)|'physical'=7.02726GB;12.76632;14.36211;0;15.9579 'physical %'=44%;80;90;0;100Code: Select all
physical_memory = CheckMEM MaxWarn=80% MaxCrit=90% ShowAll type=physicalCode: Select all
/usr/local/nagios/libexec/check_nrpe -H x.x.x.x -p 5666 -c physical_memory
OK: physical: Total: 15.958GB - Used: 7.087GB (44%) - Free: 8.871GB (55%)|'physical'=7.08733GB;12.76632;14.36211;0;15.9579 'physical %'=44%;80;90;0;100Be sure to check out our Knowledgebase for helpful articles and solutions!
@rhassing:
@lmiltchev
I read it could be a problem in the configuration of NSClient++. I followed this instructions: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
My version of NSClient++ is 0.4.3.131.
My nsclient.ini:
nagios@localhost:/usr/local/nagios/libexec$ snmpwalk -v2c -c public <host ip> 1.3.6.1.2.1.25.2.3.1
Timeout: No Response from <host ip>
nagios@localhost:/usr/local/nagios/libexec$ check_nrpe -H <host ip> -p 5666 -c CheckMEM -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
CHECK_NRPE: Error - Could not complete SSL handshake.My version of NSClient++ is 0.4.3.131.
My nsclient.ini:
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; PASSWORD - Password used to authenticate against server
password = <password>
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = <host ip>
[/settings/NRPE/server]
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
use ssl = true
; PORT NUMBER - Port to use for NRPE.
port = 5666
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = true
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = true
; ALLOW INSECURE CHIPHERS and ENCRYPTION - Only enable this if you are using legacy check_nrpe client.
insecure = false
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket. none The server will not send a client certificate request to the client, so the client will not send a certificate. peer The server sends a client certificate request to the client and the certificate returned (if any) is checked. fail-if-no-cert if the client did not return a certificate, the TLS/SSL handshake is immediately terminated. This flag must be used together with peer. peer-cert Alias for peer and fail-if-no-cert. workarounds Various bug workarounds. single Always create a new key when using tmp_dh parameters. client-once Only request a client certificate on the initial TLS/SSL handshake. This flag must be used together with verify-peer
verify mode = peer-cert
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket. default-workarounds Various workarounds for what I understand to be broken ssl implementations no-sslv2 Do not use the SSLv2 protocol. no-sslv3 Do not use the SSLv3 protocol. no-tlsv1 Do not use the TLSv1 protocol. single-dh-use Always create a new key when using temporary/ephemeral DH parameters. This option must be used to prevent small subgroup attacks, when the DH parameters were not generated using "strong" primes (e.g. when using DSA-parameters).
ssl options = no-sslv2,no-sslv3
[/modules]
; CheckExternalScripts - Execute external scripts
CheckExternalScripts = 1
; CheckHelpers - Various helper function to extend other checks.
CheckHelpers = 1
; NSClientServer - A server that listens for incoming check_nt connection and processes incoming requests.
NSClientServer = 1
; CheckNSCP - Use this module to check the healt and status of NSClient++ it self
CheckNSCP = 1
; NRPEServer - A server that listens for incoming NRPE connection and processes incoming requests.
NRPEServer = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; CheckDisk - CheckDisk can check various file and disk related things.
CheckDisk = 1
; CheckEventLog - Check for errors and warnings in the event log.
CheckEventLog = 1
; A list of templates for wrapped scripts.
%SCRIPT% will be replaced by the actual script an %ARGS% will be replaced by any given arguments.
[/settings/external scripts/wrappings]
; POWERSHELL WRAPPING -
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
; VISUAL BASIC WRAPPING -
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
; BATCH FILE WRAPPING -
bat = scripts\\%SCRIPT% %ARGS%
; A list of aliases available.
An alias is an internal command that has been predefined to provide a single command without arguments. Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = check_uptime
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = check_service "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = check_service
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = check_process "filter=is_hung" "crit=count>0"
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = check_process "process=$ARG1$" "crit=state != 'started'"
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = check_cpu "warn=load > $ARG1$" "crit=load > $ARG2$" time=5m time=1m time=30s
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = check_eventlog
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = check_cpu
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = check_drivesize
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = check_memory
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = check_drivesize
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = check_files "path=$ARG1$" "crit=size > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${size}" max-dir-depth=10
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = check_tasksched show-all "filter=title eq '$ARG1$'" "detail-syntax=${title} (${exit_code})" "crit=exit_code ne 0"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = check_process "process=$ARG1$" "crit=state != 'stopped'"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = check_process "process=$ARG1$" "warn=count > $ARG2$" "crit=count > $ARG3$"
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = check_tasksched "filter=status = 'running'" "detail-syntax=${title} (${most_recent_run_time})" "crit=most_recent_run_time < -$ARG1$"
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = check_files "path=$ARG1$" "crit=written > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${written}" max-dir-depth=10
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = check_drivesize
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = check_drivesize
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = check_tasksched show-all "syntax=${title}: ${exit_code}" "crit=exit_code ne 0"Re: Why Nagios shows more memory than the real?
First you should allow your Nagios server to do snmp queries to the host.
Rob Hassing
Thanks!! Works!!
Anyway, I will like do it with nrpe too.
Edit:
In the commands.cfg I put:
And in windows.cfg I put:
And all work fine! But if I try to define the command with arguments doesn't work:
commands.cfg:
windows.cfg:
Why? What is wrong?
Thanks!
Edit:
# 'check_mem_win' command definition
command_name check_mem_win
command_line $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ -C public -m "^Physical Memory$" -w 90 -c 95
}Code: Select all
host_name <host name>
service_description Memory Usage
# check_command check_nt!MEMUSE!-w 90 -c 95
check_command check_mem_win
}commands.cfg:
command_line $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ -C public -m "^Physical Memory$" -w $ARG1$ -c $ARG2$
}Code: Select all
check_command check_mem_win!90!95
}Thanks!
