[root@tor-nagios-01 maps]# which nfdump
/usr/local/bin/nfdump
[root@tor-nagios-01 maps]# nfdump -V
nfdump: Version: NSEL-NEL1.6.13
Further, I have installed linux machine to send netflow according
https://library.nagios.com/library/prod ... k-analyzer
and it is working fine for this source.
Also, that switch is configured to send data to windows based system and data is recognized.
Which version of Netflow is prefered for NagiosNA?
No data available
Re: No data available
I have personally seen more success from version 1.6.13, but the recommendation ultimately depends on what works for you.
Have we tried setting up a different source for the switch in question? I'm wondering if it would make a difference.Also, that switch is configured to send data to windows based system and data is recognized.
Update. I have installed NagiosNA on the other system. Mentioned above switch shows only bandwidth and no other data, some forums are saying that is not netflow capable device, not sure about it. I also setup other devices and everything looks fine. Thanks for help.
Thanks for the feedback, rafdwo! Is it safe to lock this topic or you want to keep it open for a while?
