NRPE v.2.15 set maximum output lenght
Re: NRPE v.2.15 set maximum output lenght
Hi.
I resolve this SSL handshake issue. It needs to compile NRPE both in server and client side
Are we all set to close this thread?
Great. How are the new payload sizes working out for you?michaelli wrote:Hi.
Hi abrist,
Thank your reply me so many questions.
I try to set define MAX_INPUT_BUFFER 16384 / 65536. The maximum characters are around 6000.
I think now the limitation is in SQL DB side. I think this value is acceptable but may be challenge by other team.
Sounds good - let us know if you have any further difficulties.
Hi abrist / jolson,
I had fixed linux nrpe maximum length.
But I don't have skill how to compile nrpe in AIX 5.3 / 6.1 and Soarlis 10 version. what package need to install for compile NRPE
In nagiosxi side, MAX_INPUT_BUFFER 65535.
Hi abrist / jolson,
After I demo /var/log/messages can display to 6000 character in nagios to others team. Their comment is want to show more and more log.
I execute check_nrpe -H 172.31.8.198 -c check_logfiles in nagiosxi. It can display more then 10000 character. Therefore, I think this is limited in DB side.
Could you help to provide the command to set this log field can store 65535 character.
Some client can more then 1 log services. Does this apply to all service log fields?
Try running the following to update the column sizes:
This will make the service and host list pages in XI look very . . . funky.
echo "alter table nagios.nagios_servicestatus modify output varchar(50000);" | mysql -pnagiosxi
echo "alter table nagios.nagios_servicestatus modify long_output varchar(50000);" | mysql -pnagiosxi
echo "alter table nagios.nagios_servicestatus modify perfdata varchar(50000);" | mysql -pnagiosxi
echo "desc nagios.nagios_servicestatus" | mysql -t -pnagiosxi | grep "output\|perfdata"Former Nagios employee
Hi abrist,
After apply your command and reboot nagios.
But it is not work. I generate 13 error messages. In nagios web, it shows 13th and 1 - 9th messages. 10 - 12th messages are missing
In nagios server, I run the command check_nrpe -H 172.31.8.198 -c check_logfiles manually. It can get all messages.
[root@nagiosxi ~]# echo "alter table nagios.nagios_servicestatus modify output varchar(50000);" | mysql -pnagiosxi
echo "desc nagios.nagios_servicestatus" | mysql -t -pnagiosxi | grep "output\|perfdata"[root@nagiosxi ~]# echo "alter table nagios.nagios_servicestatus modify long_output varchar(50000);" | mysql -pnagiosxi
[root@nagiosxi ~]# echo "alter table nagios.nagios_servicestatus modify perfdata varchar(50000);" | mysql -pnagiosxi
[root@nagiosxi ~]# echo "desc nagios.nagios_servicestatus" | mysql -t -pnagiosxi | grep "output\|perfdata"
| output | mediumtext | YES | | NULL | |
| long_output | mediumtext | YES | | NULL | |
| perfdata | mediumtext | YES | | NULL | |
[root@nagiosxi ~]#
[root@nagiosxi libexec]# ./check_nrpe -H 172.31.8.198 -c check_logfiles
CRITICAL - (13 errors) - Jun 19 09:49:30 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 013 ...
tag /var/log/messages CRITICAL
Jun 19 09:49:02 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 001
Jun 19 09:49:04 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 002
Jun 19 09:49:06 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 003
Jun 19 09:49:08 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 004
Jun 19 09:49:10 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 005
Jun 19 09:49:14 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 006
Jun 19 09:49:16 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 007
Jun 19 09:49:18 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 008
Jun 19 09:49:20 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 009
Jun 19 09:49:23 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 010
Jun 19 09:49:25 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 011
Jun 19 09:49:27 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 012
[b]Jun 19 09:49:30 gssons02 root: ####<Jun 15, 2015 11:07:07 PM GMT+08:00> <Error> <HTTP> <cpspap11> <onl1-ms1b> <[ACTIVE] ExecuteThread: '6' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <44c8c11e970ceb1f:-cc987b4:14d780461e3:-7ff9-0000000000000936> <1434380827145> <BEA-101104> <Servlet execution in servlet context ServletContext@682766619[app:CPO_Service_WAR-R7_1_P02-C1 module:CP_Service_WAR-0.3.0.0-R7_1-20150505-P02.war path:/cplusservice spec-version:2.5] failed, java.io.IOException: Write Channel Closed. END 013[/b]
Is the output above the full output from the check?
