I would like to display more log output from check_logfiles. In check_logfiles.cfg, I have set report=long, maxlenght 8192.
I run check_logfiles in client, it can output long log output.
But when I trigger nrpe check_logfiles in nagios, the output is limited to 1024 characters.
I would like to re-compile the nrpe and set a large output buffer. Could you tell me which parameter in common.h I need to set and provide the procedure for compile and installation. Which folder / files I need to backup before install nrpe in nagios server side?
Below is nrpe v2.15 common.h config.
#define PROGRAM_VERSION "2.15"
#define MODIFICATION_DATE "09-06-2013"
#define OK 0
#define ERROR -1
#define TRUE 1
#define FALSE 0
#define STATE_UNKNOWN 3 /* service state return codes */
#define STATE_CRITICAL 2
#define STATE_WARNING 1
#define STATE_OK 0
#define DEFAULT_SOCKET_TIMEOUT 10 /* timeout after 10 seconds */
#define DEFAULT_CONNECTION_TIMEOUT 300 /* timeout if daemon is waiting for connection more than this time */
#define MAX_INPUT_BUFFER 2048 /* max size of most buffers we use */
#define MAX_FILENAME_LENGTH 256
#define MAX_HOST_ADDRESS_LENGTH 256 /* max size of a host address */
#define NRPE_HELLO_COMMAND "_NRPE_CHECK"
#define MAX_COMMAND_ARGUMENTS 16
/**************** PACKET STRUCTURE DEFINITION **********/
#define QUERY_PACKET 1 /* id code for a packet containing a query */
#define RESPONSE_PACKET 2 /* id code for a packet containing a response */
#define NRPE_PACKET_VERSION_3 3 /* packet version identifier */
#define NRPE_PACKET_VERSION_2 2
#define NRPE_PACKET_VERSION_1 1 /* older packet version identifiers (no longer supported) */
#define MAX_PACKETBUFFER_LENGTH 1024 /* max amount of data we'll send in one query/response */
typedef struct packet_struct{
int16_t packet_version;
int16_t packet_type;
u_int32_t crc32_value;
int16_t result_code;
char buffer[MAX_PACKETBUFFER_LENGTH];
}packet;
/**************** OPERATING SYSTEM SPECIFIC DEFINITIONS **********/
#if defined(__sun) || defined(__hpux)
# ifndef LOG_AUTHPRIV
# define LOG_AUTHPRIV LOG_AUTH
# endif
# ifndef LOG_FTP
# define LOG_FTP LOG_DAEMON
# endif
