Issue with email format
stecino
Re: Issue with email format
Post by stecino »
tgriep wrote:Do you have any other multi-line plugins running and are they working?
Can you run your check from a shell on your server and post the output here?
Can you upload your script so we can review it?
No I don't have any multi-line plugins. I will use postfix to send out a multiline message
Here is the python code, it's essentially connects to replica set, runs a query. Takes json like output, converts to true json format, and then parses out the result field of output
query_result looks something like this
query_result={"ok": 1.0, "result": [{"total": 3, "_id": "serverX"},{"total": 2, "_id": "serverY"}]}
#!/usr/bin/python
from pymongo import Connection
import datetime
from bson.son import SON
import json
import sys
db = Connection(["server01.test.com:28001","server02.test.com:28001","server03.test.com:28001"]).ssp0
db.authenticate("xxxx","xxxx")
start = datetime.datetime.now() - datetime.timedelta(minutes=5)
pipeline = [
{ "$match": {"popDate":{ "$lt":start}}},
{ "$group": {"_id":"$lockHost","total":{"$sum":1}}}
query_result=db.batchPushMessageTask.aggregate(pipeline)
#convert into valid json format
query_result=json.dumps(query_result)
#load the json
json_string=json.loads(query_result)
array_length=len(json_string['result'])
#print array_length
if array_length == 0:
print ('No Errors')
sys.exit(0)
else:
for i in xrange(len(json_string['result'])):
print ("\rServer %s has %s batch push messages that are older than 5 minutes " % (json_string['result']['_id'],json_string['result']['total']))
sys.exit(2)
stecino
Post by stecino »
Looks like it may be a in issue with Postfix.
I have generated an email using a test file with multiline in it. It's treating it as single line. Will be investigation little more. let you know what happens
Keep us posted!
