Nagios Core Error
venkatklr
Re: Nagios Core Error
Post by venkatklr »
Thanks once again. one more query, do I need to install NRPE on nagios core server to monitor host?
Venkat
venkatklr
Post by venkatklr »
I am getting error (PFA for error and cfg details) while restarting nagios server after editing test.cfg file (created new .cfg to add windows server details) Please help!
Venkat
logs.docx
(43.98 KiB) Downloaded 102 times
venkatklr
Post by venkatklr »
Please can some one help me please.
I will address the following points, but if you have further questions please open new threads for them. Handling multiple separate issues in one thread leads to long posts like this and they get very hard to follow.
venkatklr wrote:Thanks once again. one more query, do I need to install NRPE on nagios core server to monitor host? t
You do not need to install NRPE on the Core server to monitor itself. You can simply run plugins locally instead of through NRPE.
venkatklr wrote:I am getting error (PFA for error and cfg details) while restarting nagios server after editing test.cfg file (created new .cfg to add windows server details) Please help!
Please run the following command as root from the Nagios server command line and post the results:
venkatklr wrote:Please can some one help me please.
Our office hours are 9AM to 5PM CDT, Monday through Friday. If you are not receiving a reply outside of those hours please be patient and someone will be along to assist you when we are back in the office.
venkatklr
Post by venkatklr »
Next time I will open new ticket.
Nagios Core 4.1.0rc1
Copyright (c) 2009-present Nagios Core Development Team and Community Contributo rs
Last Modified: 02-18-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 8 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 1 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
[root@localhost ~]#
ssax
Dreams In Code
Post by ssax »
Try running this command:
service nagios start
Then right after run this command and post the full output:
journalctl -xn
Most likely you are running into this post: http://support.nagios.com/forum/viewtop ... 758#p75758
