XI - Network Switch Router Wizard Not Retrieving All ports
brdr
Re: XI - Network Switch Router Wizard Not Retrieving All po
Post by brdr »
Thanks guys. I will send email with description and link thread.
ssax
Dreams In Code
Post by ssax »
Locking the topic since it was moved into a ticket.
Edit:
The problem was because the device was not returning the alias so when you select to use port name they all showed up as No-Description and they basically replaced each other because the service description was the same, the solution was to change the service description to unique values, you could also use port number and that would work as well.
