NSClient - ERROR: PDH Collection thread not running.
Re: NSClient - ERROR: PDH Collection thread not running.
The command from the documentation just enabled the NRPE server on the remote host. It does not set the IP address so just run it as shown.
nscp settings --activate-module NRPEServer --add-defaults
Post by Box293 »
You typed --active-module not --activate-module as well and followed by an IP address. It appears you did not follow the guide.
If you need to start again:
http://sites.box293.com/nagios/guides/n ... t-ini-file
If you follow the guides step by step you shouldn't have any problems (copy and paste saves spelling mistakes).
wangyu
Post by wangyu »
Thanks very much for Box293, I complete this operation :
http://sites.box293.com/nagios/guides/n ... dows/0-4-x
Post by Box293 »
Did it resolve your original problem?
wangyu
Post by wangyu »
I want to ask Why me recreate a nsclient.ini File ?
When I finish install NSclient software, the nsclient.ini file is exist in C:\Program Files\NSClient++ folder .
Post by Box293 »
Sometimes people manually edit the file and make changes that are not vaild and cause more problems trying to troubleshoot issues. When you start fresh, it makes things simpler.
Is your original problem resolved?
wangyu
Post by wangyu »
When I finish install the NSCP-0.4.1.105-Win32.msi on nagios client.
The picture 68 show the config of the services.cfg
The picture 67 show the status of the Drive.
hsmith
Agent Smith
Post by hsmith »
wangyu wrote:When I finish install the NSCP-0.4.1.105-Win32.msi on nagios client.
Did you make sure that your Nagios server is allowed to talk to your remote box running NSClient? You can used allowed hosts = to make sure they are allowed to talk.
snippet from my working nsclient.ini:
[/settings/default]
; PASSWORD - Password used to authenticate against server
password = supergoodpassword
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 192.168.4.67, 192.168.4.11
Former Nagios Employee.
me.
wangyu
Post by wangyu »
The nagios server is 10.134.40.139
The nagios client is 10.245.36.32
The file nsclient.ini show the configure, please look at the picture 12.
Post by Box293 »
Can you please post your entire nsclient.ini file
