NSClient - ERROR: PDH Collection thread not running.
wangyu
Post by wangyu »
When I use nagios server monitor a Windows server.
The status of check-cpuload , check-memory ,check-runtime are unknown
Please look at the picture 35.
What's the wrong with this problem ?
How can I solve this problem ?
Re: NSClient - ERROR: PDH Collection thread not running.
Post by Box293 »
It sounds like the performance counters on the Windows box need fixing.
From the windows box run:
lodctr /R
After that restart the NSClient++ service.
If that doesn't fix it, what version of NSClient++ is running on this server?
wangyu
Post by wangyu »
The version of NSClient is 0.2.7
Post by Box293 »
Was your problem fixed with my command?
You need to upgrade, I've been using Nagios since 2009 and I've never used the 2.x versions.
I would uninstall, delete any existing NSClient++ directories and install from scratch.
Here's a guide:
http://sites.box293.com/nagios/guides/n ... dows/0-4-x
wangyu
Post by wangyu »
The Step I install NSClient-0.2.7 is :
C:> cd /D C:\NSClient++
C:\NSClient++>nsclient++ /install
C:\NSClient++>nsclient++ SysTray
C:\NSClient++>nsclient++ /start
How could I uninstall nsclient-0.2.7? also uninstall it from services.msc ?
hsmith
Agent Smith
Post by hsmith »
wangyu wrote:The Step I install NSClient-0.2.7 is :
You're not able to uninstall it via control panel? That's how I've always done it.
Former Nagios Employee.
me.
wangyu
Post by wangyu »
I can't uninstall it via control panel ,because the nsclient-0.2.7 is not exist in the control panel
Post by Box293 »
Does this work?
nsclient++ /uninstall
wangyu
Post by wangyu »
It's OK ,thanks very much !
wangyu
Post by wangyu »
I install NSCP-0.4.1.105-Win32 on nagios client .
The IP of the nagios client is 10.245.36.32
The IP of the nagios server is 10.134.40.139
When I input this command on nagios client ,please see picture 53.
Whether the command I input is wrong ?
The picture 52 show the method box293 use how to configure NSCP-0.4.1.105-Win32 .
The question is the three step :
Type nscp settings --activate-module NRPEServer --add-defaults and press Enter
This may prompt you for permission
Type nscp settings --path /settings/NRPE/server --key "allow arguments" --set true and press Enter
Type nscp settings --path /settings/NRPE/server --key "allow nasty characters" --set true and press Enter
According to my understand ,the NRPEServer is nagios client ,so I replace the NRPEServer to 10.245.36.32
The Picture 53 show I input.
But it not execute successful ,so Box293 ,please tell me how could I input the command realation to the three step.
The NRPEServer is nagios client ? or The NRPEServer is nagios server ?
