Some questions about NCPA
RandomGuy86
Re: Some questions about NCPA
Post by RandomGuy86 »
lmiltchev wrote:1.
grep nag /etc/group
2. service iptables stop
3. Also, I wanted to see the "nagios.conf", not the "nagios.cfg". It should be in: "/etc/httpd/conf.d/nagios.conf".
1.
nagios:x:501:
nagcmd:x:502:nagios,apache
2. What's the command to start them again?
service iptables start
3.
nagios.conf
(1.64 KiB) Downloaded 187 times
edit:
Okay, tried to make my own command for active checks. This survives the validation check:
	command_name		check_ncpa
	command_line		/usr/local/nagios/libexec/./check_ncpa.py -H $HOSTADDRESS$ -t nagi_os_NCPA -M CPU/Percentage
	use			generic-service
	host_name		winserver
	service_description	NCPA CPU Percent
	check_command		check_ncpa
However it produces the following error message in the web interface:
(Return code of 13 is out of bounds)
Okay, it returns a different error message now... I guess check_ncps.py returns value is not compatible to the web interface?!
Also, I've tried to use added arguments:
	command_line		/usr/local/nagios/libexec/check_ncpa.py -H $HOSTADDRESS$ -t nagi_os_NCPA -M $ARG1$
	use			generic-service
	host_name		winserver
	check_command		check_ncpa|CPU
If I try to vertify that it returns 1 error:
Error: Service check command 'check_ncpa|CPU' specified in service 'NCPA CPU Percent' for host 'winserver' not defined anywhere!
Yes, you can start iptables by running:
As for the command and a service definitions, can you try the following?
   command_line      /usr/local/nagios/libexec/check_ncpa.py -H $HOSTADDRESS$ $ARG1$
   use         generic-service
   host_name      winserver
   check_command      check_ncpa!-t 'nagi_os_NCPA' -P 5693 -M cpu/percent -w 80 -c 90
Let me know if this helped. Thank you!
RandomGuy86
lmiltchev wrote:As for the command and a service definitions, can you try the following?
Oh, I understand why my method was not working; I used "|", not "!", as a delimiter. Thanks.
Btw: Is two arguments the maximum?
I still get the error "(Return code of 13 is out of bounds)", though.
So, any idea how to get the NRDP server working? That's the config file of NRDP if it is of any help:
nrdp.conf
(344 Bytes) Downloaded 198 times
You can place whatever you want after the delimiter - it is still going to be "$ARG1$". See the plugin's usage by running:
/usr/local/nagios/libexec/check_ncpa.py -h
Where do you see this error? Can you show us a screenshot? Also, show us the actual command run from the command line, along with the output of it.
RandomGuy86
lmiltchev wrote:Where do you see this error? Can you show us a screenshot? Also, show us the actual command run from the command line, along with the output of it.
Command:
/usr/local/nagios/libexec/check_ncpa.py -H 192.168.56.1 -t 'nagi_os_NCPA' -P 5693 -M cpu/percent -w 80 -c 90
Output:
OK: percent was 29%,30%,33% | 'percent_0'=29%;80;90; 'percent_1'=30%;80;90; 'percent_2'=33%;80;90;
Screenshot: (the other error message can be ignored, they are using outdated code)
The good news is that your check works from the command line. Let's find out why it is failing in the web UI.
Did you restart nagios after making the changes to the "check_ncpa" command and the "NCPA CPU Percent" service definitions? Can you post these two configs along with the "winserver" host's config?
RandomGuy86
Just to be sure I entered these two commands again:
/etc/rc.d/init.d/nagios reload
Not really changed anything in this file except that windows.cfg should be loaded:
nagios.cfg
(43.78 KiB) Downloaded 186 times
I did not removed the old code here:
windows.cfg
(4.25 KiB) Downloaded 218 times
"winservers" host config (NCPA.cfg on the client):
ncpa.cfg
(1.11 KiB) Downloaded 201 times
I didn't see any issues in these configs. I would recommend removing the command definition from windows.cfg and placing it in commands.cfg (for consistency):
Can you run the following commands and post the output:
uname -a
cat /etc/*release
ls -la /usr/local/nagios/libexec/check_ncpa.py
/usr/local/nagios/libexec/check_ncpa.py -V
ps -ef | grep bin/nagios
RandomGuy86
uname -a
Linux Scientific.Linux.Server 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 12:55:33 CDT 2015 x86_64 x86_64 x86_64 GNU/Linux
cat /etc/*release
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Scientific Linux release 6.7 (Carbon)
-rwxr--r--. 1 root root 9332  8. Sep 06:25 /usr/local/nagios/libexec/check_ncpa.py
check_ncpa.py, Version 0.3.5
nagios    1784     1  0 Sep08 ?        00:00:43 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios    1814  1784  0 Sep08 ?        00:00:25 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root      2342  2597  0 22:28 pts/0    00:00:00 grep bin/nagios
nagios   32746  1784  0 20:14 ?        00:00:03 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   32747  1784  0 20:14 ?        00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   32748  1784  0 20:14 ?        00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   32749  1784  0 20:14 ?        00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
RandomGuy86
Solved my issue with active checks with NCPA.
If you ever encounter this "error of 13" error, the most likely cause seems to be wrongly set owner of rwx rights of a file; in my case it was the file check_ncpa.py. The user Nagios was not allowed to execute the file.
The following command fixed this issue for me:
chmod o+x usr/local/nagios/libexec/check\_ncpa.py
Alternatively one could also give ownership to the user Nagios.
edit:
Okay, I still have an issue with NCPA when the client is Linux.
To make sure the Nagios Server can connect to the Linux Client I've added the following line to /etc/sysconfig/iptables
-A INPUT -p tcp --dport 5693 -j ACCEPT
However I cannot access the API from another machine.
When I disable iptables it works.
edit2:
Another little issue I have with NCPA:
How do I translate this URL:
https://192.168.56.1:5693/api/memory/virtual?check=1?token=nagi_os_NCPA
Into a command: (in particular the ?check=1)
/usr/local/nagios/libexec/check_ncpa.py -H 192.168.56.1 -t nagi_os_NCPA -P 5693 -M memory/virtual -n M ?check=1
So, now I just have to get my passive checks working (with NRDP).
