CPU 100% alerts
angus
Re: CPU 100% alerts
Post by angus »
I went through this process, https://assets.nagios.com/downloads/ncp ... on-windows, but the -q arg is still not showing as an option. Please assist.
Thank you.
Re: CPU 100% alerts
Can we check the check_ncpa.py version that is installed in your XI system? Can you run the following and post back the output?
/usr/local/nagios/libexec/check_ncpa.py --version
/usr/local/nagios/libexec/check_ncpa.py --help
angus
Re: CPU 100% alerts
Post by angus »
See the attachment please.
Thanks.
Re: CPU 100% alerts
Post by Box293 »
That screenshot shows you have an older version of check_ncpa.py on your XI server.
Download the latest version here:
https://raw.github.com/NagiosEnterprise ... ck_ncpa.py
Upload the plugin:
Click the Admin menu
System Extensions > Manage Plugins
Click the Browse button
Find the check_ncpa.py file
Click Open
Click The Upload Plugin button
Now it should be the 0.3.5 version.
Does this fix your problem?
angus
Re: CPU 100% alerts
Post by angus »
All set, thanks.
I didn't realize i just needed to copy the text into a file and upload it. I was looking for an actual file to download.
Thanks.
hsmith
Agent Smith
Re: CPU 100% alerts
Post by hsmith »
Are we all right to consider this one resolved?
Former Nagios Employee.
me.
angus
Re: CPU 100% alerts
Post by angus »
Yes.
