So as my test indicates, moving to nsclient++ will offer you the data you want.
Obviously this will require some retooling in your environment that you may not want to do, however it should be noted that SNMP will no longer be an option for Windows come version 2012 anyway:
https://technet.microsoft.com/en-us/library/hh831568
The only other alternative I readily see is to change the check_snmp plugin code and recompile.
memory performance graph
jdalrymple
- Skynet Drone
murawweh.daher
Re: memory performance graph
i run nrpe and result as below, is there any thing missing? the value didn't displayed in percentage.
is there customized plugin without need to install the agent?.
/usr/local/nagios/libexec/check_nrpe -H nnmi -t 180 -c checkmem -a MaxWarn=95% MaxCrit=98%
OUTPUT: OK memory within bounds.
Regards,
Murawweh Daher
Murawweh Daher
What is the version of the NSClient++ agent that you are currently using? My check shows % as expected.i run nrpe and result as below, is there any thing missing? the value didn't displayed in percentage.
[root@testbox libexec]# /usr/local/nagios/libexec/check_nt -H <client ip> -s <password> -p 12489 -v CLIENTVERSION
NSClient++ 0.4.3.143 2015-04-29
[root@testbox libexec]# /usr/local/nagios/libexec/check_nrpe -H <client ip> -t 180 -c checkmem -a MaxWarn=95% MaxCrit=98%
OK: committed: Total: 31.914GB - Used: 7.844GB (24%) - Free: 24.07GB (75%), physical: Total: 15.958GB - Used: 7.118GB (44%) - Free: 8.84GB (55%)|'committed'=7.84401GB;30.31836;31.27578;0;31.91406 'committed %'=24%;94;97;0;100 'physical'=7.1183GB;15.16001;15.63875;0;15.9579 'physical %'=44%;95;97;0;100Be sure to check out our Knowledgebase for helpful articles and solutions!
