memory performance graph
murawweh.daher
Hi everybody;
i checking the memory and the result in performance graph displayed in MB.
How can i display it in percentage instead of MB?
Regards,
Murawweh Daher
Murawweh Daher
Re: memory performance graph
Can you post which plugin you are running?
Depending on the plugin, if you add the percent to your warning and critical thresholds, that could change the performance output to percentage.
murawweh.daher
i use check_snmp_mem
$USER1$/check_snmp_mem.pl -H $HOSTADDRESS$ $ARG1$
what the best plugin used to check memory in percentage?
Regards,
Murawweh Daher
Murawweh Daher
Think tom is correct- you can just get percentage output from passing the % symbol with the warning and critical:
Check this manual and since there different ways to send the command based on device, etc just find what you are looking for and test the command until it outputs how you would like.
http://nagios.manubulon.com/snmp_mem.html
/Luke
jdalrymple
- Skynet Drone
It depends on the platform you're monitoring. Honestly I don't know of any for Linux, but I do believe that check_nrpe for Windows (NSCP) offers perfdata in percentage:
[jdalrymple@localhost libexec]$ ./check_nrpe -H <winhost> -c checkmem -a MaxWarn=95% MaxCrit=98%
OK: committed: Total: 31.91GB - Used: 11.318GB (35%) - Free: 20.592GB (64%), physical: Total: 15.91GB - Used: 9.968GB (62%) - Free: 5.942GB (37%)|'committed'=11.31803GB;30.31476;31.27207;0;31.91028 'committed %'=35%;94;97;0;100 'physical'=9.96821GB;15.11476;15.59207;0;15.91028 'physical %'=62%;95;97;0;100
**edit**
**edit**
I can't confirm this:lgroschen wrote:Think tom is correct- you can just get percentage output from passing the % symbol with the warning and critical:
[jdalrymple@localhost libexec]$ ./check_snmp_mem.pl -H 127.0.0.1 -C public -w 90%,90% -c 95%,95% -f
Argument "v6.0.1" isn't numeric in numeric lt (<) at ./check_snmp_mem.pl line 465.
Ram : 60%, Swap : 8% : ; OK | ram_used=598144;903089;953260;0;1003432 swap_used=175712;1887433;1992291;0;2097148-
murawweh.daher
i tested it before but still in graph the value in MB.
Regards,
Murawweh Daher
Murawweh Daher
Can you go to that service check and click on the advanced tab and verify the performance data is now returning a percentage value?
If it is, you will need to delete the xml and rrd file for that service and the graph will start to populate for you.
murawweh.daher
i checked it and was in MB, i remove the xml and rrd files, and wait until rebuild it, but all of that was not work, still display it in MB.
Regards,
Murawweh Daher
Murawweh Daher
jdalrymple
- Skynet Drone
As I stated, it doesn't appear that the plugin you're using does what you want. It will either have to be customized or you will need to use a different plugin
We need to know what platform you're monitoring to be able to help further.
.jdalrymple wrote:It depends on the platform you're monitoring. Honestly I don't know of any for Linux, but I do believe that check_nrpe for Windows (NSCP) offers perfdata in percentage:
murawweh.daher
