Waiting for configuration verification
Re: Waiting for configuration verification
Post by Box293 »
Is it possible for you to try Apply Config using Firefox or Chrome so we can rule out any issues with the XI server.
JohnFLi
Post by JohnFLi »
it did seem to work correctly with Chrome.
Everybody is somebody else’s weirdo
Likely has something to do with standards or Compatibility Mode. Does it work for Firefox as well? IE8 is 6 years old and I am almost certain we are using at least Javascript techniques that are not going to work in a browser that old.
JohnFLi
Post by JohnFLi »
Yeah.....I'm not able to update IE on the machine I use for the Nagios Gui. But as long as it actually does restart the nagios service...I guess thats what really matters.
I did find another issue since the update. I will create a new thread. It deals with setting a schedualed downtime.
hsmith
Agent Smith
Post by hsmith »
Firefox is tested working for you as well then? Can we do anything else for you regarding this?
Former Nagios Employee.
me.
JohnFLi
Post by JohnFLi »
I dont have firefox to test with, but it works with chrome.
you can go ahead and close this. thanks
