Waiting for configuration verification
JohnFLi
Post by JohnFLi »
I just updated to the latest version of XI.
When I make a change to a service (or anythign else) and click APPLY CHANGES.... I just get the spining circle saying "Waiting for configuration verification.........................................."
yet, If I go to CCM then click on the new blue button that says "Verify configuration"
it tells me
Checking objects...
Checked 140 services.
Checked 24 hosts.
Checked 2 host groups.
Checked 0 service groups.
Checked 22 contacts.
Checked 8 contact groups.
Checked 125 commands.
Checked 16 time periods.
Checked 0 host escalations.
Checked 24 hosts
Checked 0 host dependencies
Checked 16 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
if i do /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
it tells me
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 24 hosts.
        Checked 24 hosts
Total Warnings: 0
Total Errors:   0
Any idea what the deal with the gui is?
Everybody is somebody else’s weirdo
jwelch
Re: Waiting for configuration verification
Post by jwelch »
Have you tried another browser or clearing the cache on your browser? Maybe it's
something from the previous version that's cached in your browser.
If that's not it, you might check to make sure you only have two nagios processes running.
ps -eaf | grep "nagios -d"
I've had some problems where I had two sets of nagios processes running and was getting
really weird stuff on the sceen...like data for hosts that I'd deleted...
Post by Box293 »
Can you run the following in an ssh session on your Nagios XI host.
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
Then go into XI and Apply Configuration.
What output is produced in the SSH session?
JohnFLi
Post by JohnFLi »
PROCESSED 0 COMMANDS
A=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
--2015-10-14 08:38:25--  http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: “nagiosql.login”
     0K .......... .......... .......... .....                 1.22M=0.03s
2015-10-14 08:38:26 (1.22 MB/s) - “nagiosql.login” saved [36107]
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=c5vnh6' -O nagiosql.loginLOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
CMDLINE
--2015-10-14 08:38:26--  http://localhost/nagiosxi/includes/components/ccm/
     0K .......... .......... .......... .....                 1.75M=0.02s
2015-10-14 08:38:27 (1.75 MB/s) - “nagiosql.login” saved [36107]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
--2015-10-14 08:38:27--  http://localhost/nagiosxi/includes/components/ccm/
Saving to: “nagiosql.export.monitoring”
     0K .......... ....                                        43.0K=0.3s
2015-10-14 08:38:27 (43.0 KB/s) - “nagiosql.export.monitoring” saved [14681]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Checking objects...
        Checked 24 hosts.
        Checked 24 hosts
Total Warnings: 0
Total Errors:   0
RET: 0
Running configuration check...
Stopping nagios: done.
Starting nagios: done.
OUTPUT=Starting nagios: done.
RETURNCODE=0
..........................^C
[root@G1VPPCINAG ~]#
Can you run the following in an ssh session on your Nagios XI host and post the output.
cd /usr/local/nagiosxi/scripts/
su nagios
JohnFLi
Post by JohnFLi »
[root@G1VPPCINAG ~]# cd /usr/local/nagiosxi/scripts/
[root@G1VPPCINAG scripts]# su nagios
[nagios@G1VPPCINAG scripts]$ ./reconfigure_nagios.sh
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=c5vnh6' -O nagiosql.login--2015-10-14 13:57:35--  http://localhost/nagiosxi/includes/components/ccm/
    [ <=>                                   ] 36,107      --.-K/s   in 0.04s
2015-10-14 13:57:36 (949 KB/s) - “nagiosql.login” saved [36107]
LOGIN SUCCESSFUL!
Array
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=c5vnh6' -O nagiosql.login--2015-10-14 13:57:36--  http://localhost/nagiosxi/includes/components/ccm/
    [ <=>                                   ] 36,107      --.-K/s   in 0.02s
2015-10-14 13:57:37 (1.79 MB/s) - “nagiosql.login” saved [36107]
LOGIN SUCCESSFUL!
CMDLINE:
--2015-10-14 13:57:37--  http://localhost/nagiosxi/includes/components/ccm/
    [  <=>                                  ] 14,681      25.9K/s   in 0.6s
2015-10-14 13:57:37 (25.9 KB/s) - “nagiosql.export.monitoring” saved [14681]
OUTPUT:
Nagios Core 4.1.1
License: GPL
Checking objects...
        Checked 24 hosts.
        Checked 24 hosts
Total Warnings: 0
Total Errors:   0
RET: 0
Stopping nagios:. done.
Post by Box293 »
Does your Nagios XI server have a proxy server defined in /etc/wgetrc ?
JohnFLi
Post by JohnFLi »
Nope
Post by Box293 »
Can you confirm you are on XI 5.2.0.
Can you respond to @jwelch suggestions.
jwelch wrote:Have you tried another browser or clearing the cache on your browser? Maybe it's
JohnFLi
Post by JohnFLi »
Your Nagios XI installation is up to date.
Latest Available Version: 5.2.0
Installed Version: 5.2.0
Last Update Check: 10/14/2015 13:59:03
yes...cleared chache, even restarted the machine
[root@G1VPPCINAG ~]# ps -eaf | grep "nagios -d"
nagios    6707     1  0 16:20 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios    6758  6707  0 16:20 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root      7313  7273  0 16:21 pts/0    00:00:00 grep nagios -d
something I just noticed in the browser IE 8 (in the lower right hand corner of the browser window, there is a yellow triangle that says "Done, but with errors on the page")
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; SLCC1; .NET CLR 2.0.50727; .NET4.0C; .NET4.0E; .NET CLR 3.0.30729; .NET CLR 3.5.30729)
Timestamp: Wed, 14 Oct 2015 23:33:16 UTC
Message: Object doesn't support this action
Line: 1
Char: 709
Code: 0
URI: http://g1vppcinag/nagiosxi/includes/js/d3/d3.v3.min.js?5.2.0
