[Fixed]Change "down" status
Re: Change "down" status
Thanks Eric. Let us know what you come up with, @aruggeri.
Former Nagios Employee.
me.
me.
Good morning guys,
I arrived at the conclusion that the problem:
for the moment I set with ip address of parent nodes as the localhost or 127.0.0.1.
As long as you keep this configuration i will take it for good, in the future go into the question.
Thank you very much for the support given i send my best regards,
Andrea
Andrea
Re: [Fixed]Change "down" status
Ah! Glad to see you were able to find the issue. Do you mind if I close this thread then?
