Nagios Output Not Graphing
Re: Nagios Output Not Graphing
No the debugging is not yet enable when i start my npcd
- Box293
- Too Basu
Can you please enable it, restart npcd and let us know the output.
Hi Box,
Is this your requested output?
Starting npcd:DEBUG: Config File = /usr/local/pnp4nagios/etc/npcd.cfg
CONFIG_OPT_LOGTYPE = syslog
CONFIG_OPT_LOGFILE = /usr/local/pnp4nagios/var/npcd.log
CONFIG_OPT_LOGFILESIZE = 10485760
CONFIG_OPT_LOGLEVEL = -1
CONFIG_OPT_SCANDIR = /usr/local/pnp4nagios/var/spool
CONFIG_OPT_RUNCMD = /usr/local/pnp4nagios/libexec/process_perfdata.pl
CONFIG_OPT_RUNCMD_ARG = --bulk
CONFIG_OPT_MAXTHREADS = 5
CONFIG_OPT_LOAD = 0.0
CONFIG_OPT_USER = nagios
CONFIG_OPT_GROUP = nagios
CONFIG_OPT_PIDFILE = /var/run/npcd.pid
CONFIG_OPT_SLEEPTIME = 15
CONFIG_OPT_IDENTMYSELF = 1
DEBUG: load_threshold is disabled - ('0.000000')
done.
- Box293
- Too Basu
Is that all that is logged in /usr/local/pnp4nagios/var/npcd.log ?
I don't have npcd.log
how can i invoke to create one?
Can you please post the output of the following commands -
service npcd status
service crond status
ls -l /usr/local/pnp4nagios/var/
Hi rkennedy,
# service npcd status
npcd (pid 21043) is running...
# ls -l /usr/local/pnp4nagios/var/
total 6094880
-rw-rw-r-- 1 nagios nagios 887510826 Nov 24 08:47 host-perfdata
drwxrwxrwx 2 nagios nagios 4096 Jul 8 2014 kohana
drwxr-xr-x 124 nagios nagios 4096 Oct 5 15:33 perfdata
-rw-rw-r-- 1 nagios nagios 5149597 Oct 22 13:40 perfdata.log
-rw-rw-r-- 1 nagios nagios 5342356654 Nov 24 08:48 service-perfdata
drwxrwxr-x 2 nagios nagios 4096 Jul 8 2014 spool
drwxr-xr-x 2 nagios nagios 4096 Oct 22 13:41 stats
Lets change the npcd.cfg file and enable logging so we can see what is going on.
Can you edit the npcd.cfg file
Comment out this line
un-comment this line
Then change this line from
to
Save the file and restart npcd by running
Let the system run for 10 minutes and then run this tail command on the npcd.log file and post the output here.
log_type = syslogCode: Select all
#log_type = fileCode: Select all
log_level = 0Code: Select all
log_level = 1Code: Select all
service npcd restartCode: Select all
tail -200 /usr/local/pnp4nagios/var/npcd.logBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi tgriep,
please see the attached file. Thank you
npcd logs.txt- (5.78 KiB) Downloaded 459 times
The logs don't lead to much except -
Are your graphs working for other services or is it only this one in question?
NPCD: No more files to process... waiting for 15 seconds
