stderr: execvp(/usr/local/nagios/libexec/check_ping, ...) fa
al_orange
Re: stderr: execvp(/usr/local/nagios/libexec/check_ping, ...
Post by al_orange »
hsmith wrote:You need to change into the nagoios-plugins directory after you untar it.
Okay, did that, received more errors:
[root@XEN1 nagios-plugins-2.1.1]# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... no
checking whether to disable maintainer-specific portions of Makefiles... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/tmp/nagios-plugins-2.1.1':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
What OS is Nagios running on?
al_orange
Post by al_orange »
rkennedy wrote:What OS is Nagios running on?
Oracle Linux 7 (64-bit).
[root@nagios etc]# cat /etc/*release*
Oracle Linux Server release 7.1
NAME="Oracle Linux Server"
VERSION="7.1"
ID="ol"
VERSION_ID="7.1"
PRETTY_NAME="Oracle Linux Server 7.1"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:oracle:linux:7:1"
HOME_URL="https://linux.oracle.com/"
BUG_REPORT_URL="https://bugzilla.oracle.com/"
ORACLE_BUGZILLA_PRODUCT="Oracle Linux 7"
ORACLE_BUGZILLA_PRODUCT_VERSION=7.1
ORACLE_SUPPORT_PRODUCT="Oracle Linux"
ORACLE_SUPPORT_PRODUCT_VERSION=7.1
Red Hat Enterprise Linux Server release 7.1 (Maipo)
[root@nagios etc]#
You are missing the C Compiler and probably other required packages. Login as root on the server and run the following to install the missing packages.
yum -y install autoconf gcc glibc libmcrypt-devel make openssl-devel sudo sysstat xinetd bc
al_orange
Post by al_orange »
tgriep wrote:You are missing the C Compiler and probably other required packages. Login as root on the server and run the following to install the missing packages.
Okay, great. The install worked. However I'm still receiving the same error message as my first post.
hsmith
Agent Smith
Post by hsmith »
Did you restart the Nagios service after installing the plugins?
Former Nagios Employee.
me.
al_orange
Post by al_orange »
hsmith wrote:Did you restart the Nagios service after installing the plugins?
Yes, using: /etc/rc.d/init.d/nagios restart
On the Nagios server, can you post the result of the following -
ls -l /usr/local/nagios/libexec/
al_orange
Post by al_orange »
rkennedy wrote:On the Nagios server, can you post the result of the following -
[root@nagios ~]# ls -l /usr/local/nagios/libexec/
total 84
-rwxrwxr-x 1 nagios nagios 81470 Nov 18 11:07 check_nrpe
drwxr-xr-x 4 nagios nagios  4096 Nov 11 15:40 eventhandlers
After you ran ./configure --with-nagios-user=nagios --with-nagios-group=nagios, did you also run
make
make install
It looks like your plugins haven't been compiled yet.
