stderr: execvp(/usr/local/nagios/libexec/check_ping, ...) fa
I'm receiving this error in nagios (the gui), in Currents Status --> Hosts:
stderr: execvp(/usr/local/nagios/libexec/check_ping, ...) failed. errno is 2: No such file or directory
- Box293
- Too Basu
Re: stderr: execvp(/usr/local/nagios/libexec/check_ping, ...
Is this in the status information column of all hosts or just one host?
A screenshot might help.
Screenshot attached.Box293 wrote:Is this in the status information column of all hosts or just one host?
- Box293
- Too Basu
Can you please post:
- One of these host definitions
If they use a template, the template definition
The command definition used by the host or the template
I'm sorry, I can't find my host definitions. Where do I find this again? In the Nagios host or Nagios server? What is the usual path?Box293 wrote:Can you please post:
Usually it's in the /usr/local/nagios/etc/ directory or a sub directory stemming from that one. Where did you create the file for the host 'ora_linux7_xxxxxxxxxx'?
Did you install the plugins when you installed core?
Can you post the result of the following command?
ls /usr/local/nagios/libexec
I'm not sure what you mean by where did I create the file. It's on another VM, on a different IP address.rkennedy wrote:Usually it's in the /usr/local/nagios/etc/ directory or a sub directory stemming from that one. Where did you create the file for the host 'ora_linux7_xxxxxxxxxx'?
Can you post the result of the following command?Code: Select all
Yes, I think I installed the plugins, but it's been a couple weeks, I don't quite remember.
For the command (on the nagios server), I got:
[root@nagios etc]# ls /usr/local/nagios/libexec
check_nrpe eventhandlersRe: stderr: execvp(/usr/local/nagios/libexec/check_ping, ...
Looks like you need to install Nagios plugins on the host server. This should work to install them -
Let us know if you run into any issues.
cd /tmp
wget http://www.nagios-plugins.org/download/nagios-plugins-2.1.1.tar.gz
tar xvf nagios-plugins-2.1.1.tar.gz
./configure --with-nagios-user=nagios --with-nagios-group=nagios
make
make install
Looks like I already ran into an issue for the host:rkennedy wrote:Looks like you need to install Nagios plugins on the host server. This should work to install them -Let us know if you run into any issues.Code: Select all
cd /tmp wget http://www.nagios-plugins.org/download/nagios-plugins-2.1.1.tar.gz tar xvf nagios-plugins-2.1.1.tar.gz ./configure --with-nagios-user=nagios --with-nagios-group=nagios make make install
[root@XEN1 tmp]# ./configure --with-nagios-user=nagios --with-nagios-group=nagios
-bash: ./configure: No such file or directory
You need to change into the nagoios-plugins directory after you untar it.
Former Nagios Employee.
me.
me.
