CheckTaskSched with tasks ending codes
ssax
Dreams In Code
Re: CheckTaskSched with tasks ending codes
Post by ssax »
I am unable to get that nsclient plugin to work how you want it, I've tried everything.. Your best bet if you want to use nsclients integrating scheduled tasks check would be to ask how to configure it on the NSClient++ forums.
I'm sure I could whip up a powershell script that would do what you want but then you would have to put that script on every windows server that you want to check scheduled tasks as and update the nsclient.ini file.
Let me know what you would like to do.
Thank you
dlukinski
Post by dlukinski »
ssax wrote:I am unable to get that nsclient plugin to work how you want it, I've tried everything.. Your best bet if you want to use nsclients integrating scheduled tasks check would be to ask how to configure it on the NSClient++ forums.
Thank you
Thank you for investigating. Existing configuration works (becomes critical with the right value configured), just does not look ideal :-)
We'll try using poweshell to make it look better (although it does work :-)
Please close this thread
