CheckTaskSched with tasks ending codes
dlukinski
Post by dlukinski »
Hello XI support
How to use CheckTaskSched to check if specific task exit code was more then or less then some value?
Thank you
Re: CheckTaskSched with tasks ending codes
Are you using the warning / critical parameters? How do you have this check currently configured?
Here's a link with a bit more information about CheckTaskSched - http://docs.nsclient.org/reference/CheckTaskSched.html
dlukinski
Post by dlukinski »
rkennedy wrote:Are you using the warning / critical parameters? How do you have this check currently configured?
I have it done as sample (from box293)
- check_nrpe!CheckTaskSched!-a "filter=title eq 'Backup - Copy to ATL' AND most_recent_run_time < -5m" "syntax=%title%: Last Run Time = %most_recent_run_time% GMT" MaxCrit=1
Tried making it something like this:
check_nrpe!CheckTaskSched!-a "filter=title eq 'Backup - Copy to ATL' AND exit_code > 8" "syntax=%title%: Last result=%exit_code% at %most_recent_run_time%" MaxWarn=0
, but getting Service check pending with (No output on stdout) stderr: /bin/sh: -c: line 0: unexpected EOF while looking for matching `"'
Can you post the exact arguments you are using with this service check? Sometimes things in the CCM get escaped when they are saved and later run.
dlukinski
Post by dlukinski »
tmcdonald wrote:Can you post the exact arguments you are using with this service check? Sometimes things in the CCM get escaped when they are saved and later run.
Latest version of check looks this way: check_nrpe!CheckTaskSched!-a "filter=title eq 'Backup - Copy to ATL' AND exit_code ne 8" "syntax=%title%: Last result=%exit_code% at %most_recent_run_time% GMT" MaxCrit+8
It produces this result (as warning) - Backup - Copy to ATL: Last result=3 at 2016-Jan-07 05:30:00 GMT
So only question left: how to make it work as "exit_code > 8" (which seem to be incorrect syntax if used exatly as written)
Usually gt is used for "Greater-Than" and lt is used for "Less-Than". Does that work?
dlukinski
Post by dlukinski »
tmcdonald wrote:Usually gt is used for "Greater-Than" and lt is used for "Less-Than". Does that work?
It becomes "task not found"
Essentially I have to get critical alerts when specific task exit code is over 8
- just can't make it work anyhow with CheckTaskSched
Just to double check, are you trying to get Nagios to return OK / WARN / CRIT alerts out of the exit_code filter?
The reason I ask is because in the documentation it states -
 filter (CheckTaskSched, check_tasksched)¶
    Filter which marks interesting items.
    Interesting items are items which will be included in the check.
    They do not denote warning or critical state but they are checked use this to filter out unwanted items.
    Avalible options:
Also, what version of NSClient++ are you running?
ssax
Dreams In Code
Post by ssax »
In addition to rkennedy's post.
Ok, after messing around with this I think I'm getting close, add the debug on the end of the command and it looks like MaxCrit is using the COUNT of how many it finds so you would need to change it to 0:
/usr/local/nagios/libexec/check_nrpe -H X.X.X.X -c CheckTaskSched -a "filter=title eq 'Backup - Copy to ATL' AND exit_code gt 8" "syntax=%title%: Last result=%exit_code% at %most_recent_run_time% GMT" MaxCrit=0 debug
dlukinski
Post by dlukinski »
ssax wrote:In addition to rkennedy's post.
Whenever I use gt - result is ": No tasks found" This makes sense because task is ending with "3" currently and we want to be notified if exit_code is over 8. However XI service creates warning this way, where we want warning to be created when result is gt 8..
check_nrpe!CheckTaskSched!-a "filter=title eq 'Copy to ATL' AND exit_code gt 8" "syntax=%title%: Last result=%exit_code% at %most_recent_run_time% GMT" MaxCrit=0 debug!!!!!!
