Configure Exim MailServer Logs With NLS
rlinux57
Re: Configure Exim MailServer Logs With NLS
Post by rlinux57 »
Elasticsearch is running. I have setup NLS via this document "Manual-Installation-Instructions-For-Nagios-Log-Server.pdf"
[root@logs ~]# cat /etc/sysconfig/logstash
# Default settings for logstash
# Override Java location
#JAVACMD=/usr/bin/java
# Set a home directory
APP_DIR=/usr/local/nagioslogserver
LS_HOME="$APP_DIR/logstash"
# set ES_CLUSTER
ES_CLUSTER=$(cat $APP_DIR/var/cluster_uuid)
# Arguments to pass to java
#LS_HEAP_SIZE="256m"
LS_JAVA_OPTS="-Djava.io.tmpdir=$APP_DIR/tmp"
# Logstash filter worker threads
#LS_WORKER_THREADS=1
# pidfiles aren't used for upstart; this is for sysv users.
#LS_PIDFILE=/var/run/logstash.pid
# user id to be invoked as; for upstart: edit /etc/init/logstash.conf
LS_USER=nagios
LS_GROUP=nagios
# logstash logging
#LS_LOG_FILE=/var/log/logstash/logstash.log
#LS_USE_GC_LOGGING="true"
# logstash configuration directory
LS_CONF_DIR="$LS_HOME/etc/conf.d"
# Open file limit; cannot be overridden in upstart
#LS_OPEN_FILES=2048
# Nice level
#LS_NICE=0
# Increase Filter workers to 4 threads
LS_OPTS=" -w 4"
if [ "x$1" == "xstart" -o "x$1" == "xrestart" -o "x$1" == "xreload" ];then
	GET_LOGSTASH_CONFIG_MESSAGE=$( php /usr/local/nagioslogserver/scripts/get_logstash_config.php )
	GET_LOGSTASH_CONFIG_RETURN=$?
	if [ "$GET_LOGSTASH_CONFIG_RETURN" != "0" ]; then
		echo $GET_LOGSTASH_CONFIG_MESSAGE
		exit 1
jolson
Attack Rabbit
Post by jolson »
It looks like you're missing two closing 'fi' commands at the end of your /etc/sysconfig/logstash file. Do they exist?
tail /etc/sysconfig/logstash
Working system:
[root@localhost sysconfig]# tail /etc/sysconfig/logstash
LS_OPTS=" -w 4"
                exit 1
        fi
fi
I imagine you're using CentOS/RHEL/Oracle Linux?
cat /etc/*relea*
Does this file exist?
ls -l /var/run/logstash/logstash.pid
How old is the nagios user account?
chage -l nagios
Twits Blog
rlinux57
Post by rlinux57 »
[root@logs ~]# tail /etc/sysconfig/logstash
LS_OPTS=" -w 4"
		exit 1
	fi
fi
cat /etc/redhat-release
CentOS release 6.7 (Final)
-rw-r--r-- 1 nagios nagios 6 Jan 27 22:51 /var/run/logstash/logstash.pid
chage -l nagios
Last password change					: Jan 18, 2016
Password expires					: never
Password inactive					: never
Account expires						: never
Minimum number of days between password change		: 0
Maximum number of days between password change		: 99999
Number of days of warning before password expires	: 7
jolson
Attack Rabbit
Post by jolson »
The PID file may be halting our attempt to start Logstash. Try the following:
mv /var/run/logstash/logstash.pid ~
service logstash restart
Twits Blog
rlinux57
Post by rlinux57 »
I have moved as per your direction but still:
Restarting Logstash Daemon:                                [FAILED]
WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
/etc/init.d/logstash: line 99: [: 5828: unary operator expected
Please attach your /etc/init.d/logstash file.
rlinux57
Post by rlinux57 »
Please find attachment.
What OS are you running?
rlinux57
Post by rlinux57 »
CentOS 6.7
rlinux57
Post by rlinux57 »
Any update ?
