Configure Exim MailServer Logs With NLS
Is there any way to monitor exim logs with NLS ?
Re: Configure Exim MailServer Logs With NLS
Is the server capable of pushing its logs out over the network?
Former Nagios Employee.
me.
me.
Yes, you should be able to use the Linux File Setup which will produce a command similar to this in your environment.
curl -s -O http://nlsip/nagioslogserver/scripts/setup-linux.sh
bash setup-linux.sh -s nlsip -p 5544 -f "/path/to/exim/logdir/*.log" -t FILE_TAG
Thanks, i'm working over it and let you know after any outcome.
Sounds good! We'll be awaiting your response.
Logstash service not working, getting below error:
Moreover i have run the script as it is that you have mentioned, is it run successfully ? :
[root@logs ~]# /etc/init.d/logstash restart
Restarting Logstash Daemon: [FAILED]
WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
/etc/init.d/logstash: line 99: [: 18169: unary operator expected
bash setup-linux.sh -s nlsip -p 5544 -f "/var/log/exim_mainlog" -t FILE_TAG
Detected rsyslog 5.8.10
Detected rsyslog work directory /var/lib/rsyslog
Destination Log Server: nlsip:5544
Processing /var/log/exim_mainlog file...
Creating /etc/rsyslog.d/90-nagioslogserver_var_log_exim_mainlog.conf...
rsyslog configuration check passed.
Restarting rsyslog service with 'service'...
Shutting down system logger: [ OK ]
Starting system logger: [ OK ]
Okay.
rsyslog is running with the new configuration.
Visit your Nagios Log Server dashboard to verify that logs are being received.
Can you post the output of this command?rlinux57 wrote:Logstash service not working, getting below error:
tail -n200 /var/log/logstash/logstash.logLooks successful to me.rlinux57 wrote:Moreover i have run the script as it is that you have mentioned, is it run successfully ? :
me.
me.
Yes, it looks like the script has succeeded.Moreover i have run the script as it is that you have mentioned, is it run successfully ? :
I have seen this before - I'd like to know if any of these options work for you:Logstash service not working, getting below error:
service logstash start
systemctl start logstash
service logstash status
systemctl status logstashRe: Configure Exim MailServer Logs With NLS
There's nothing in /var/log/logstash:
[root@logs ~]# ll /var/log/logstash/
total 0
[root@logs ~]# service logstash start
Starting Logstash Daemon: WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
/etc/init.d/logstash: line 99: [: 21959: unary operator expectedCode: Select all
[root@logs ~]# service logstash status
Logstash Daemon dead but pid file existsRe: Configure Exim MailServer Logs With NLS
How did you set up Nagios Log Server initially - via VM template or manually?
Is elasticsearch running before you attempt to start Logstash?
I'd like to see this file:
Did you attempt to upgrade Logstash or Elasticsearch from our default versions? I've seen this issue happen in testing when I tried to move Logstash to >=2.0
service elasticsearch startCode: Select all
cat /etc/sysconfig/logstash
