XI installation on CentOS 7
gbnag
Re: XI installation on CentOS 7
Post by gbnag »
Thought about using the virtual appliance and might go that route eventually.
Since the installer cannot locate an rpm like in this case 'No package centos-release-cr available' went ahead and located it via google, then
downloaded and placed it into /etc/yum.repos.d.
Installed via yum install:
[root@gberger-linux-centos yum.repos.d]# yum install centos-release-cr-6-0.el6.centos.x86_64.rpm
Loaded plugins: fastestmirror, security
Setting up Install Process
Examining centos-release-cr-6-0.el6.centos.x86_64.rpm: 10:centos-release-cr-6-0.el6.centos.x86_64
Marking centos-release-cr-6-0.el6.centos.x86_64.rpm to be installed
Resolving Dependencies
--> Running transaction check
---> Package centos-release-cr.x86_64 10:6-0.el6.centos will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
centos-release-cr x86_64 10:6-0.el6.centos /centos-release-cr-6-0.el6.centos.x86_64 509
Transaction Summary
Install 1 Package(s)
Total size: 509
Installed size: 509
Is this ok [y/N]: y
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : 10:centos-release-cr-6-0.el6.centos.x86_64 1/1
Verifying : 10:centos-release-cr-6-0.el6.centos.x86_64 1/1
Installed:
Complete!
Reran the ./fullinstall and after a minute got this error:
Complete!
Fixing php-mcrypt bug...
Prerequisites installed OK
RESULT=0
Running './2-usersgroups'...
Adding users and groups...
useradd: user 'nagios' already exists
groupadd: group 'nagios' already exists
ERROR: User 'nagios' was not created - exiting.
RESULT=1
INSTALLATION ERROR!
install.log attached.
hsmith
Agent Smith
Post by hsmith »
Can you remove the nagios user and groups, and try again? Is there something else that would have created this user/group?
Former Nagios Employee.
me.
