Attempted to install XI but getting installation error:
Enabling CentOS 6 Continuous Release repo...
Loaded plugins: fastestmirror, security
Setting up Install Process
Loading mirror speeds from cached hostfile
* epel: fedora.westmancom.com
* rpmforge: mirror.teklinks.com
No package centos-release-cr available.
Error: Nothing to do
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'
Had no problem getting the latest tar.gz downloaded via wget.
It has been suggested to post to this forum for any insight.
XI installation on CentOS 7
Re: XI installation on CentOS 7
Is this a clean system?
What's the output of these commands?
Are you using a proxy?
cat /etc/*release*
uname -aFormer Nagios Employee.
me.
me.
Hi, sorry for the delay.
gberger-linux-centos nagiosxi]# cat /etc/*release*
CentOS release 6.7 (Final)
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
cat: /etc/lsb-release.d: Is a directory
cpe:/o:centos:linux:6:GA
[root@gberger-linux-centos nagiosxi]# uname -a
Linux gberger-linux-centos 2.6.32-573.el6.x86_64 #1 SMP Thu Jul 23 15:44:03 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
[root@gberger-linux-centos nagiosxi]# cat install.log
Nagios XI Installation Log
DATE: Wed Jan 27 16:44:22 PST 2016
DISTRO INFO:
CentOS
6.7
x86_64
THIS IS A NEW INSTALL!
INSTALLING:
full=5.2.3
major=5
minor=2.3
releasedate=2015-12-07
release=514
Configuring Repos...
centos-release-6-7.el6.centos.12.3.x86_64
rpmforge-release RPM installed OK
epel-release RPM installed OK
* epel: mirror.utexas.edu
* rpmforge: mirrors.neusoft.edu.cn
Regards,
DISTRO INFO:
CentOS
6.7
x86_64
INSTALLING:
full=5.2.3
major=5
minor=2.3
release=514
Regards,
Forgot to answer the other 2 questions.
The system got built by our server admin team, so expect it to be as clean as possible. And we do not use proxies.
Can I please see the output of these 2 commands?
yum repolist
ls /etc/yum.repos.d/Former Nagios Employee.
me.
me.
hello,
Here is the output:
gberger@gberger-linux-centos<1> # yum repolist
Determining fastest mirrors
epel/metalink | 13 kB 00:00
* epel: ftp.osuosl.org
* rpmforge: ftp.tu-chemnitz.de
Packages | 4.0 kB 00:00
QC.stage | 2.5 kB 00:00
Security | 2.4 kB 00:00
epel | 4.3 kB 00:00
errata | 2.4 kB 00:00
nagios-base | 1.5 kB 00:00
nagios-base 151/151
nagiosxi-deps | 1.5 kB 00:00
nagiosxi-deps 33/33
rpmforge | 1.9 kB 00:00
repo id repo name status
Packages Packages 6,575
QC.stage QC.stage 215
Security Security 0
*epel Extra Packages for Enterprise Linux 6 - x86_64 11,924
errata errata 0
nagios-base Nagios 151
nagiosxi-deps Nagios XI Dependencies 33
rpmforge RHEL 6 - RPMforge.net - dag 4,718
repolist: 23,616
-- /usr2/gberger -- 16:52
berger@gberger-linux-centos<2> # ls /etc/yum.repos.d/
disabled/ epel-testing.repo mirrors-rpmforge mirrors-rpmforge-testing Packages.repo rpmforge.repo
epel.repo errata.repo mirrors-rpmforge-extras nagios-6.repo QC.stage.repo Security.repo
-- /usr2/gberger
Here is the output:
epel | 4.3 kB 00:00
nagios-base 151/151
nagiosxi-deps 33/33
Security Security 0
errata errata 0
repolist: 23,616
-- /usr2/gberger
This is starting to look like there are quite a few modifications on this system. Where are the CentOS repos?
me.
me.
Looks like CentOS7 is not fully supported by our admin team.
Is there a way to opt out of using the CR during the XI installation process?
Usage of the CR repository is entirely optional to a system administrator, and is based on their express actions to opt-in.
If you're not able to use the repositories that our installation script uses by default, you can look inside of the fullinstall script and make any changes necessary to make Nagios XI work in your environment. In making those changes, it may not be a supported system anymore.
Another option you could pursue is to use our VM template, which is based on CentOS 6 and can be found here. If you need to remove the CentOS repositories from this machine, just be warned that it my not be able to be upgraded in the future.
me.
me.
